aftermarket gauges in sammy
  • 2733 Views
« on: March 01, 2011, 02:48:43 PM »
I want to install a aftermarket oil and temp gauge in my dash on my 94 samurai. Does anyone know where a good spot to tap into for the oil pressure and water temp on the engine?  Thanks Dan
Offline Jluck
  • 1389
  • 40
Re: aftermarket gauges in sammy
« Reply #1 on: March 01, 2011, 02:56:25 PM »
There's usually a plug above the oil filter on the block that works well or you can just tee in to existing sender. Please use a copper or braided line for oil pressure instead of the plastic crap. I have watched more than one motor seize due to plastic lines breaking.
And on water gauge; mechanical or electric?
« Reply #2 on: March 01, 2011, 03:17:35 PM »
For water temperature try to find an unused port on the intake manifold - avoid putting the sensor in the radiator hose(s) - if you do, there will be no indication of temperature until the thermostat opens and coolant circulates - and if the thermostat fails shut, the engine will overheat with the gauge moving from cold.
« Reply #3 on: March 01, 2011, 03:31:09 PM »
That a good idea with the copper instead of plastic line i will keep that in mind..I really havent decided on electric or mechanical water temp gauge..Is there a unused port on the intake?
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #4 on: March 02, 2011, 08:54:31 AM »
if you have round vent dash with a clock you ca mount the gauges in the vent bezels i did it look awsome
