can you adjust the door catches/latches
  • 7 Replies
  • 4468 Views
« on: February 05, 2011, 04:32:00 PM »
I am having trouble searching the forums, dont know what the thingy is called.  I would like to adjust-if possible-how the doors shut and latch.  One I have to slam to make the door shut all the way, one works great. Is it a door latch/keeper/catch????  I am sure the answer is in the forums, I am just not searching the right terms cuz I aint sure what its called.
Thanks a ton.
Jesse in Knoxville
Offline Jluck
  • 1389
  • 40
Re: can you adjust the door catches/latches
« Reply #1 on: February 05, 2011, 04:49:25 PM »
striker might be the word your looking for. what are you working on? most of the time IMO the door latch will need replaced.
« Reply #2 on: February 05, 2011, 07:55:56 PM »
The striker is the piece on the door jamb (the body) and is usually adjustable - up/down, in/out - the lock is the piece on the door.  I've never had to replace either part.  There will also be handles, both inside & outside, those are usally made of plastic and break quite easily.
Since you say you have to slam the door - I would guess the striker needs to be moved outwards, but before I did that I would check the rubber door seal to make sure it's not preventing the door from closing properly.
« Reply #3 on: February 06, 2011, 06:50:49 AM »
Yes, the striker is adjustable.  Just loosen up the big screws and tap the striker with a hammer to move it and retighten the screws.
If this happens to be a samurai, check the body where the rubber door strap attaches.  A lot of times the body lip gets bent out a little bit, from the door being opened too "hard" (either by the wind catching it, or someone just "winging" the door open) and it will bend the lip behind the door strap (you can easily see it, if this is the case).  If it is bent, you can take a board and hammer and bend it back in, to keep the door from hitting on it so hard, and the door will close much easier then.
Offline joe dirt
  • 148
« Reply #4 on: February 06, 2011, 09:37:35 AM »
if this is a tracker or sidekick,..double check the the hinges are not pulling out through the body,..they are known for rusting out at the hinges,...i had to take both my doors off and weld in a completly new plate for the hinges to bolt to
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
« Reply #5 on: February 06, 2011, 09:48:10 AM »
Thanks to all the input.  Got my door closing perfectly now.  You guys are awesome!  and I learned a new word for the day-striker
Rock on.
« Reply #6 on: February 08, 2011, 10:03:46 AM »
Rock on.
So what was it....tracker, sidekick, samurai?
« Reply #7 on: February 12, 2011, 02:09:35 PM »
sorry, it is an 88.5 samurai
