Driver side Brake light wont work
travd123
2
November 03, 2011, 10:01:44 AM »
Hi Im having an issue with these new stock replacement taillights. I bought 2 Yesterday from LR and hooked them up and all lights work except the driverside brake light. If anyone may no how i can resolve this problem i would appreciate the help.. thanks
travd123
2
Re: Driver side Brake light wont work
November 03, 2011, 10:23:21 AM »
Whoops forgot this is for a 1986 samurai..
fordem
4333
170
November 03, 2011, 11:29:12 AM »
If you're having a problem with a single brake light, the problem with either be the bulb, the bulb holder or the wiring - start by swapping the bulb from the other side across, and then proceed from there.
Drone637
8121
116
Evil Cow
Reply #3 on:
November 03, 2011, 04:06:39 PM »
Check your grounds as well. Most lighting issues can be traced back to bad ground wires on the Suzuki's.
fordem
4333
170
Reply #4 on:
November 03, 2011, 07:23:31 PM »
I did consider a bad ground - but - the other lamps on the same side (tail, turn, etc.) will also use the same ground, so that should be intact.
P Funk
29
Reply #5 on:
November 06, 2011, 04:56:54 PM »
Look at where the ground wire connects to the bulb holder. If it gets corroded it will break the contact and stop working. It took me a month to find the same problem. Hope this helps.
