Pinion Flange Question
hollywood514
11
February 11, 2011, 06:58:14 PM »
Can you switch out the small flange's on 88 center section for the large one's on a 90
both are samurai
Thanks Bob
Last Edit: February 11, 2011, 07:04:53 PM by hollywood514
wildgoody
8134
67
Re: Pinion Flange Question
February 11, 2011, 07:14:07 PM »
I think they will swap over, so long as they are both 26 splines
Skyhiranger
3734
122
I don't buy, what I can build
February 12, 2011, 05:47:17 PM »
As long as they are the same spline
type
, then they will interchange fine. They are all the same spline count, it is just the spline type that may be different. Here is some info to know what type each are...
http://bbs.zuwharrie.com/content/topic,55582.0.html
When you swap flanges you should check the pinion bearing preload as well (which means you need to disassemble the third). Some people don't bother to check it and are fine....others aren't....so it's up to you on what you want to do.
