Speedometer cable removal
  • 1 Replies
  • 2032 Views
Offline jga154
  • 28
    • Jim Arnold Blog
« on: November 03, 2011, 06:48:32 PM »
86 Samurai; Can the speedometer cable be removed without draining the fluid first or will all the fluid leak out?
Thanks,
Jim
86 Samurai Tin top, OME Springs, Bonz shackles, 30x9.50, 4.9:1 TC, rear Lockright locker, Rocky Road Outfitters DIY front bumper
Re: Speedometer cable removal
« Reply #1 on: November 04, 2011, 08:13:59 AM »
Yes, you can remove just the cable from the tcase and no fluid will leak out.  Remove the bolt from the bottom part of the tcase speedo assembly, wiggle the cable and it should slide right out.
