SUZUKI SAMARI SJ413
SUZUKI SAMARI SJ413
JAMES44
46
ZUKIWORLD Online!
SUZUKI SAMARI SJ413
July 30, 2016, 09:14:47 AM »
The gear change has become quite stiff to operate....oil level is okay do the selectors need a drop of oil on them
thanks jim
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: SUZUKI SAMARI SJ413
July 30, 2016, 12:48:13 PM »
Is the clutch properly adjusted? have you checked the gearbox oil level?
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
td57
76
4
July 30, 2016, 10:15:18 PM »
Pull the shifter out of the transmission & check the shift pin & sheet.
It's could be that they either are broken or worn out.
JAMES44
46
ZUKIWORLD Online!
Reply #3 on:
July 31, 2016, 02:12:46 AM »
Will check clutch aadjustment today thanks jim
JAMES44
46
ZUKIWORLD Online!
Reply #4 on:
July 31, 2016, 02:16:00 AM »
will check also oil level is okay
jim
