96/97 aftermarket double din
  • 1333 Views
Offline SoCal87
  • 28
« on: August 26, 2018, 01:19:49 AM »
 Does anyone know if a aftermarket double din will fit without needing a bezel or modified brackets?
1990 Geo Tracker LSI 4x4 2dr
1996 Geo Tracker LSI 4x4 4dr
Re: 96/97 aftermarket double din
« Reply #1 on: August 26, 2018, 01:46:21 AM »
The double DIN fits with a bezel kit. They're cheap and easy to get. It will be a universal type bezel that will require you to cut some tabs. Order the kit when you order the wiring adapter.
Offline trkrpwr
  • 23
« Reply #2 on: August 26, 2018, 05:07:20 AM »
I've got a 98 that had factory double din and I swapped it out with just a harness adapter. A bezel kit would provide a more finished look but, depending on the face plate, it may not be needed.
