Best High Steer? - Samurai
  • 19 Replies
  • 11053 Views
Offline z3ro
  • 339
« on: January 27, 2011, 01:57:16 PM »
There are several hi-steer products on the market, and I'm about ready to change my z-link for a hi-steer.
LRO - Stage 1 and 2 for ~$365
RRO - Stage 2 and 2 for ~$385
TT - $279
Which one?  I plan on doing the CJ/YJ swap soon too.  Right now I have SPOA with RUF.
« Last Edit: January 27, 2011, 02:14:56 PM by z3ro »
Offline z3ro
  • 339
Re: Best High Steer? - Samurai
« Reply #1 on: January 27, 2011, 02:25:30 PM »
Forgot to add the z-bar eliminator kit from Petroworks for $289.
Offline Jluck
  • 1389
  • 40
« Reply #2 on: January 27, 2011, 02:44:10 PM »
check with skys offroad too
http://www.sky-manufacturing.com/new/
Offline z3ro
  • 339
« Reply #3 on: January 27, 2011, 08:16:31 PM »
Sky stuff is what LRO sells I think.
I'm just gonna do a CJ swap and leave my RUF on.  From what I've read, it's the best setup aside from a coil conversion. The YJ is nice and all, but I'd rather drop that coin on a roll cage and/or a swap.
Looks like Petroworks doesn't have any z-bar eliminators at the moment.  I'm leaning that way unless I hear otherwise.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #4 on: January 27, 2011, 08:53:19 PM »
  Calmini high steer kit has more mounting points and may be stronger.
Offline doughboy0379
  • 290
  • 9
  • Blinker fluid is free so use it........
« Reply #5 on: January 28, 2011, 12:24:37 AM »
 z3ro when you get your new steering done let me know how much you want for that z-link I am still in need of one.
86 Samurai, SPOA, 3" HD leaf springs, 31/10.5/15 Big-O XT Tires, K&N Air Filter, Doug Thorey Header, more coming when I find the funds :)
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #6 on: January 28, 2011, 12:27:34 PM »
calmini take a rim with 2.5" back spacing i find that a pain with my calmini kit i dont know about the others
Offline flexmonger
  • 209
« Reply #7 on: January 28, 2011, 12:36:40 PM »
   Thats just the price you pay for having a stronger steering arm.
« Reply #8 on: January 28, 2011, 01:58:40 PM »
I have the Sky cross-over kit.   It keeps the stock lower tie rod so it's not a full cross-over but it also saves you a hundred bucks.
http://www.sky-manufacturing.com/new/detaproduct.php?id=178
I've never had an issue with it.  The tie rod will bend before the steering arm will break.
Offline thefirstzukman
  • 69
« Reply #9 on: January 28, 2011, 09:54:15 PM »
Low range is coming out with a new kit that is better than anything out there, hold out until then.
Offline z3ro
  • 339
« Reply #10 on: January 29, 2011, 01:52:41 PM »
Any details?
Offline MadMaxZuki
  • 77
« Reply #11 on: January 29, 2011, 04:35:54 PM »
i have Sky's full high steer works great. only thing id that i noticed my turning radius went to shit after i blamed it on the bigger tires (im turning 33's) until someone else said the same thing and he didnt increase tire size. i dont know if it because of the shorter drag link or what? also what make a kit better than anything else in terms of strength, like drone said a tie rod will bend be4 and cast aluminum steering arm will break. Also if you use Sky's set up a drag link off of an FJ80 axle is perfect length for the high steer tie rod
« Last Edit: January 29, 2011, 04:38:59 PM by MadMaxZuki »
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Offline airmanwilliams
  • 913
« Reply #12 on: January 29, 2011, 08:54:51 PM »
I just asked sean about the steering they are working on developing and his response is this.
"We have had one installed for about a month on dans
We have made a few changes to the arms and are trying to decide on machining or forging them
the first prototype arm cost $350"
hopfully the cost will come down, I am going down this week and will take alook at it on dans samurai and if I have permission from them I will post it up along with more details if you want them.
1993 4door Suzuki Sidekick JX
« Reply #13 on: January 31, 2011, 10:35:57 AM »
Usually the steering going to pot is caused by the need to install a panhard bar.  The suspension will have to much flex and soak up the steering.  I can be wrong though, as reasons may vary.
Offline z3ro
  • 339
« Reply #14 on: February 02, 2011, 09:11:16 PM »
Ugh.  Low Range is so expensive ...
