Fender Trimming
  • 16 Replies
  • 9462 Views
0 Members and 15 Guests are viewing this topic.
Offline mike5721947
  • 545
Re: Fender Trimming
« Reply #15 on: August 18, 2010, 10:23:38 PM »
i ran 235's stock and now with just over 2 inchs of lift on the front no problems (bit of rub on the frame at full lock, took the hammer to it and its gone now)
with the 3 inchs of lift 31's fit with some rub. that spot on the rear of the fender rubs slightly on flex with steering, then a little on the frame at full lock.
all depends on the rims. im running standard sidekick 9 hole rims (15x5.5) bit skinny for the 31's but they work well. rear stuffs right up in flex does touch when loaded down and it squats on bumps.
all in all its giving me ideas on what to do next to get some room for my chains...
31" kumhos 3inchs of lift.
Offline Medford
  • 184
Re: Fender Trimming
« Reply #16 on: August 19, 2010, 04:16:06 AM »
Yes, I believe it will do it for me.  Thanks for the help.
96 Tracker LSI, 2.5" Pro Comp lift with cooper 30X9.5 STT tires.  A bit of trim and beating to make the front work.
