need help with rear spring
safarikick
270
nor-cal rhinos
March 29, 2010, 06:41:46 PM »
hi
i have a 97 sidekick with a 3 in calmini lift. i have a made a rear bumper and tire rack. I have gear in the back of the truck it will sit low in the back. i was thing of using air lift bag inside of the rear coil spings.
http://www.summitracing.com/parts/AIR-60793/
3+3 calmini 5.12 a lock in the back and front with steel front diff. 4.24 in tc
ppltrak
654
zukspeed staff
Re: need help with rear spring
March 29, 2010, 08:32:39 PM »
the air bag will not be tall enough. your best bet is a higher PPI spring rate.
kevin
94 purple/green splash tracker w/ calmini 3' heavly modified lift 32 11.5 r15 bfg m/t's & custom air induction and header w/ 2"exh. no cat lockrite rear 2" B/L and a heavy right foot and now 583s steel up front and locked.
djlantis57
871
13
Take your chrome home
March 30, 2010, 12:12:46 PM »
Maybe a spring spacer in the rear only? Just a guess. That would give you more height ALL the time though, but could help it sit a little better when loaded. It'd be cheap. Just a thought
God put me on earth to accomplish a certain number of things. Right now I am so far behind, I will never die.
