X-90 ring and pinion upgrade
  • 19 Replies
  • 7038 Views
Offline drenalin
Re: X-90 ring and pinion upgrade
« Reply #15 on: November 26, 2011, 04:30:00 PM »
If i just swap my rear end with a sidekick rear end that should do the trick ...or should i swap front ends as well ?
Offline SnoFalls
  • 1358
« Reply #16 on: November 27, 2011, 04:03:52 AM »
You must make sure both differentials are running the same ratio.
Put 5.125 diffs in (easy to find), and with 30-31inch tires you'll be back close to factory gearing.
FYI, your x-90 came with 4.625 diff gears stock.
« Reply #17 on: November 30, 2011, 09:58:54 AM »
A couple of things.... Rhino is correct, X-90's did NOT come with the 5.12 gears They are 4.?? stock so a factory 5 speed Kick R&P will help you out and they are easy to come by.
Second, (I dont know if this was covered) The T-Case reduction is an AWESOME addition to any trail 4x4 BUT the Kick/X-90/Tracker reductions leave high range stock, there will be no on road benefit/rediction, so done be expecting it.
And Last (yea, I know, more than a couple)  ;), there was a company (one of our sponsors) that was coming out with a in line reduction about a year or so ago. I can not remember who or what it was called, but one hell of an idea.... Hopefully someone else can jump in here and remind me who/what it was.
Offline SnoFalls
  • 1358
« Reply #18 on: November 30, 2011, 12:20:39 PM »
I'm suspecting you're referring to trail tough and the Undertaker. While I find it a nice solution, I just don't think it's worthy for a SWB trac/kick ...
« Reply #19 on: November 30, 2011, 03:04:13 PM »
Yeah, I remembered it was something like that. Simon Touron who built Generation-X90 years ago put a 5:12 axle in his and it wouldn't go anywhere in 4wd! it stuck in my mind  ::) ::)
