X-90 ring and pinion upgrade
  • 19 Replies
  • 6970 Views
Offline drenalin
« on: November 23, 2011, 01:07:01 PM »
I would like to upgrade the gearing a bit on my x-90 , 1997 , 1.6l , 16v .... i am running 30" bf mud terrains now but may get 31's next ...what would be the ideal pinion and ring gear ratio  for me to drop in it ?  Right now i have no take off power till i get up over 3000 rpm which sometimes takes awhile, especially on the hills.
 Would just changing the rear ring and pinion do the trick ?  the front end is stock independant , i wouldn't really need to modify this as well would i ?
And where is the best place to get a good ring and pinion gear set for my x-90 ?
Offline talonxracer
  • 1284
Re: X-90 ring and pinion upgrade
« Reply #1 on: November 23, 2011, 01:33:30 PM »
The optimum would be the factory 5.63 gears. They would have to be sourced used as they are no longer carried by Suzuki and no one makes R&P's in the aftermarket for the sidekick/tracker/x90. Expect to pay a premium price.
Offline drenalin
« Reply #2 on: November 23, 2011, 01:49:17 PM »
Really , noone makes aftermarket gears ?  so what can i look for when parts searching to determine the gear ratio of the rear end ?  and compatibility ?
Offline drenalin
« Reply #3 on: November 23, 2011, 01:54:12 PM »
What would my stock rearend be running for gears?  just woundering the reduction % from stock to 5.63 ?
« Reply #4 on: November 23, 2011, 02:09:15 PM »
The stock X90 should be 4.66s or thereabouts so you would get a reasonable reduction with the 5:12s from a 5sp Track/Kick
Offline talonxracer
  • 1284
« Reply #5 on: November 23, 2011, 02:18:49 PM »
The factory offered the 5.63 and a 5.38 R&P on a very limited amount of sidekicks years ago, Calmini used to have a 5.88 but they were discontinued. Those are your only real options, if it fits a sidekick it fits the x90 as they have the same frame and drivetrain, just different bodies.
 Not sure what your current gear ratio is, what transmission do you have? I am not for sure positive but I thought i remember reading some x90's didnt have 5.12 R&P from the factory so that would be an improvement.
Another option is to go with a 260 torquer cam and a Doug Thorley tri-Y header for more power down low in the rpm range where you are mostly driving.
Offline drenalin
« Reply #6 on: November 23, 2011, 02:53:24 PM »
Yah it definatly need more power ...lol , i have found a couple site that are selling 5.38 ring gears but they are backordered . How hard is it to change a ring and pinion on these zukies , will i have to heat the ring gear like i've seen others do , i have never changed one before , quick learner though !! I also discovered 4:62.1  tranny case gears for low range torque %134 gain , might be a future upgrade .
Offline DonD
  • 140
« Reply #7 on: November 23, 2011, 03:31:20 PM »
I just installed 4.24:1's in my Tracker TC..very high crawl reduction..redline in low range 5th is 25mph!!
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
Offline drenalin
« Reply #8 on: November 23, 2011, 04:28:40 PM »
That sounds too low for my driving applications . I use my rig for hunting and playing , dirt roads and maybe logging trails .
Offline talonxracer
  • 1284
« Reply #9 on: November 23, 2011, 06:01:14 PM »
That is exactly the types of terrain I drive on in the mtns, mostly logging/skidder trails, hunting, and back/dirt road driving, as well as just running into town(20 minute drive on dirt and pavement).
I am running 31x10.5's with 5.12 gears in my 98' Sidekick and she is slightly down on power, the 4.24 transfercase gears are the very next upgrade planned here shortly, even before the torquer cam.
Offline drenalin
« Reply #10 on: November 23, 2011, 06:10:18 PM »
Buddy just posted a t case with those gears in it for 550.00 in classifids .
« Reply #11 on: November 23, 2011, 10:16:06 PM »
you need around 5.62 to bring you back to stock. trying to get to the same place.
88 Sammy coils front,rear. 8:1 tcase,5:12,and 37-12.5-16.5 on double beadlocks. arb front spooled back.
96 X90
00 Vitara
Offline drenalin
« Reply #12 on: November 24, 2011, 03:17:45 AM »
I wouldn't even mind having a little better out of the gate punch than stock , she only goes 100 km's /h full out now , the lower gears will will cause me to loose even more top end speed won't they ?    still a good trade off !!
Offline talonxracer
  • 1284
« Reply #13 on: November 24, 2011, 01:44:23 PM »
You will gain power everywhere and get a hiigher top speed, with your current gearing the engine just cant provide enough power to get to a higher speed.
« Reply #14 on: November 26, 2011, 03:54:14 PM »
I don't think any X90s had 5:12s from the factory
