Camoplast tracks
  • 2711 Views
Camoplast tracks
« on: April 20, 2011, 12:01:25 PM »
Recently purchased 98 Sidekick 4dr 4WD with the intention of installing Camoplast Tatou 4S tracks.  Anybody out there have any experience/recommendations on suspension/body lifts for the vehicle.  I want to make sure I get good enough clearances, but yet don't want to get too extreme.  I'm thinking of the emu 2" suspension and 2" body lift.  Your thoughts?  Thanks
Re: Camoplast tracks
« Reply #1 on: April 20, 2011, 03:00:17 PM »
Do you need much of a lift to run the tracks?  The OME 2" lift alone would probably be enough.
« Reply #2 on: April 20, 2011, 05:18:11 PM »
That's exactly what I'm trying to figure out.  I e-mailed atvtracks.net hoping to get this info.  The reply was that I should check the forums because there is a lot of info on them.  I was hoping someomne who has installed these track on a sidekick would chime in.  I know there are alot out there and have been highly syuccessful using these tracks.
« Reply #3 on: April 20, 2011, 05:20:53 PM »
I have seen a couple with the Mattrax.  I don't believe a lift was required.
« Reply #4 on: April 20, 2011, 07:57:29 PM »
I agree with Drone, but, I also think that an adapter kit is needed for each wheel position, so you might want to check some more.
