Another 1.6L 8 valve swap
zuki87jx
31
May 30, 2010, 01:42:17 PM »
Bobthebiker
Re: Another 1.6L 8 valve swap
May 30, 2010, 03:03:44 PM »
Generally, with japanese vehicles in general, you can do 99% of the work on one with an 8 through 19mm socket. MOST things are 8 10 or 12mm usually, but never hurts to be prepared. 250 for a low miles running motor isnt bad.
zuki87jx
31
May 30, 2010, 04:05:40 PM »
Ok thanks I'll be sure to post up some pics when I get the project rolling.
Andrew
wildgoody
8134
67
Reply #3 on:
May 30, 2010, 05:59:25 PM »
17mm on the engine to trans bolts
dupont#24
48
2
Deer hunter
Reply #4 on:
May 30, 2010, 08:59:40 PM »
Go ahead and get wiring harness out send it to Brent It will be the best thing you every done just got threw putting a 89 in my sammy.I bought all my stuff from TT but I will tell you one thing the 89 motor has a taller throttle body you may want to look at another place for the motor mounts.I had to make a hood scope fore mine because I didn't want to go with a body lift Don't take me wrong TT is the best Brent was the one who told me about the 89 sits a little taller.just letting you know
zuki87jx
31
Reply #5 on:
May 30, 2010, 09:21:54 PM »
I wanting to stay carbed is it still necessary to swap the wiring harness? Also since I am staying carbed will I still have a bad hood clearance issue?
Thanks for the tip on the trans bolts
Andrew
Last Edit: May 30, 2010, 09:25:11 PM by zuki87jx
dupont#24
48
2
Deer hunter
Reply #6 on:
May 31, 2010, 05:56:38 AM »
I dont know if you stay carb someone else can tell you if you will have any problems you will use the harness thats in the sammy
Drone637
8121
116
Evil Cow
Reply #7 on:
May 31, 2010, 10:42:21 PM »
If your staying carbed you will keep your existing engine wiring, your just swapping the long block at that point.
Not sure on the hood though. Should be ok.
zuki87jx
31
Reply #8 on:
June 01, 2010, 09:44:20 AM »
Ok cool thanks guys and the only other things I should need from the donor is the alt and the starter right?
dupont#24
48
2
Deer hunter
Reply #9 on:
June 01, 2010, 04:35:02 PM »
Starter for sure don't know about alternator I run the Gm alternator
zuki87jx
31
Reply #10 on:
June 01, 2010, 06:25:11 PM »
As far as the fuel pump should I go buy a universal electric or is there one from another vehicle that I can snag while I'm at the pick n pull. I should be going tomorrow or Friday to pick everything up
