Another 1.6L 8 valve swap
  • 10 Replies
  • 3017 Views
Offline zuki87jx
  • 31
« on: May 30, 2010, 01:42:17 PM »
Bobthebiker
Re: Another 1.6L 8 valve swap
« Reply #1 on: May 30, 2010, 03:03:44 PM »
Generally,  with japanese vehicles in general,  you can do 99% of the work on one with an 8 through 19mm socket.   MOST things are 8 10 or 12mm usually,  but never hurts to be prepared.     250 for a low miles running motor isnt bad.
Offline zuki87jx
  • 31
« Reply #2 on: May 30, 2010, 04:05:40 PM »
Ok thanks I'll be sure to post up some pics when I get the project rolling.
Andrew
« Reply #3 on: May 30, 2010, 05:59:25 PM »
17mm on the engine to trans bolts
Offline dupont#24
  • 48
  • Deer hunter
« Reply #4 on: May 30, 2010, 08:59:40 PM »
Go ahead and get wiring harness out send it to Brent It will be the best thing you every done just got threw putting a 89 in my sammy.I bought all my stuff from TT but I will tell you one thing the 89 motor has a taller throttle body  you may want to look at another place for the motor mounts.I had to make a hood scope fore mine because I didn't want to go with a body lift Don't take me wrong TT is the best Brent was the one who told me about the 89 sits a little taller.just letting you know
Offline zuki87jx
  • 31
« Reply #5 on: May 30, 2010, 09:21:54 PM »
I wanting to stay carbed is it still necessary to swap the wiring harness? Also since I am staying carbed will I still have a bad hood clearance issue?
Thanks for the tip on the trans bolts
Andrew
« Last Edit: May 30, 2010, 09:25:11 PM by zuki87jx »
Offline dupont#24
  • 48
  • Deer hunter
« Reply #6 on: May 31, 2010, 05:56:38 AM »
I dont know if you stay carb someone else can tell you if you will have any problems you will use the  harness thats in the sammy
« Reply #7 on: May 31, 2010, 10:42:21 PM »
If your staying carbed you will keep your existing engine wiring, your just swapping the long block at that point.
Not sure on the hood though.  Should be ok.
Offline zuki87jx
  • 31
« Reply #8 on: June 01, 2010, 09:44:20 AM »
Ok cool thanks guys and the only other things I should need from the donor is the alt and the starter right?
Offline dupont#24
  • 48
  • Deer hunter
« Reply #9 on: June 01, 2010, 04:35:02 PM »
Starter for sure don't know about alternator I run the Gm alternator
Offline zuki87jx
  • 31
« Reply #10 on: June 01, 2010, 06:25:11 PM »
As far as the fuel pump should I go buy a universal electric or is there one from another vehicle that I can snag while I'm at the pick n pull. I should be going tomorrow or Friday to pick everything up  :D
