oil pump gasket
oil pump gasket
airdale navy
82
2
oil pump gasket
October 19, 2012, 01:43:10 PM »
The oil pump I ordered came with a metal gasket.Does it need sealant?Or does it go on dry?Or maybe copper coat?Any thoughts?Thanks!
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
airdale navy
82
2
Re: oil pump gasket
October 19, 2012, 04:57:41 PM »
Anyone used a metal gasket on oil pump? Any leaking issues?
bentparts
4536
60
I'd rather be Blown AND Injected.
Re: oil pump gasket
October 21, 2012, 04:31:24 AM »
The one I just installed also came with a metal gasket. For extra leak insurance I coated both sides with " The Right Stuff " black RTV before install. For fiber, paper or rubber gaskets I use Permetex High Tack coating on both sides of the gasket.
airdale navy
82
2
Re: oil pump gasket
Reply #3 on:
October 21, 2012, 11:10:58 AM »
I used 2 coats of copper coat.No leaks.
bentparts
4536
60
Re: oil pump gasket
Reply #4 on:
October 21, 2012, 06:18:22 PM »
I'm pretty sure that just about any good sealer would work .
