oil pump gasket
  • 1908 Views
Offline airdale navy
  • 82
oil pump gasket
« on: October 19, 2012, 01:43:10 PM »
The oil pump I ordered came with a metal gasket.Does it need sealant?Or does it go on dry?Or maybe copper coat?Any thoughts?Thanks!
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
  • 82
Re: oil pump gasket
« Reply #1 on: October 19, 2012, 04:57:41 PM »
Anyone used a metal gasket on oil pump? Any leaking issues?
Re: oil pump gasket
« Reply #2 on: October 21, 2012, 04:31:24 AM »
The one I just installed also came with a metal gasket. For extra leak insurance I coated both sides with " The Right Stuff " black RTV before install. For fiber, paper or rubber gaskets I use Permetex High Tack coating on both sides of the gasket.
  • 82
Re: oil pump gasket
« Reply #3 on: October 21, 2012, 11:10:58 AM »
I used 2 coats of copper coat.No leaks.
Re: oil pump gasket
« Reply #4 on: October 21, 2012, 06:18:22 PM »
I'm pretty sure that just about any good sealer would work .
