slip yoke elminator
slip yoke elminator
rocktracks
6
I Love ZUKIWORLD!
slip yoke elminator
October 21, 2006, 07:19:27 AM »
I would like to know if anybody had any luck on elminating the slip yoke inside the trac/kick t-cases I have a 89 tin top and I am putting toy axles in it with leafs.I know you can go to ott to get there kicker 2 setup to run a toy t-case behind yours but I would be looking close to a grand for this set up. any help would be great.I have the lower t-case gears already and mine is a two door.That's why I would like to stay with a single t-case to cut down on the drive angle in the back.If you have any pictures can you e-mail me them at pat.courchesne|removethispart|@sympatico.ca thanks you in advance
37kicker
319
3
97 tracker 9inch front and rear on 40" pitbulls
Re: slip yoke elminator
October 22, 2006, 01:37:57 PM »
ihave done it on a tracker i built its not to difficult with the right equip. stan
rocktracks
6
I Love ZUKIWORLD!
October 23, 2006, 06:54:15 AM »
how did you make it stan and is it holding up
37kicker
319
3
Reply #3 on:
October 23, 2006, 05:52:32 PM »
i machined out the shaft & threaded it so i could bolt on the yolk. it's working great. stan
tech
12
I Love ZUKIWORLD!
Reply #4 on:
October 25, 2006, 05:59:34 PM »
i drilled and tapped the output shafts front and rear and made custom flanges that welded on to my stock slip yokes
