slip yoke elminator
  • 1634 Views
Offline rocktracks
  • 6
slip yoke elminator
« on: October 21, 2006, 07:19:27 AM »
I would like to know if anybody had any luck on elminating the slip yoke inside the trac/kick t-cases I have a 89 tin top and I am putting toy axles in it with leafs.I know you can go to ott to get there kicker 2 setup to run a toy t-case behind yours but I would be looking close to a grand for this set up. any help would be great.I have the lower t-case gears already and mine is a two door.That's why I would like to stay with a single t-case to cut down on the drive angle in the back.If you have any pictures can you e-mail me them at pat.courchesne|removethispart|@sympatico.ca   thanks you in advance ;D
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
Re: slip yoke elminator
« Reply #1 on: October 22, 2006, 01:37:57 PM »
 ihave done it on a tracker i built its not to difficult with the right equip.    stan
Offline rocktracks
  • 6
« Reply #2 on: October 23, 2006, 06:54:15 AM »
how did you make it stan and is it holding up
Offline 37kicker
  • 319
« Reply #3 on: October 23, 2006, 05:52:32 PM »
i machined out the shaft & threaded it so i could bolt on the yolk.  it's working great.         stan
Offline tech
« Reply #4 on: October 25, 2006, 05:59:34 PM »
i drilled and tapped the output shafts front and rear and made custom flanges that welded on to my stock slip yokes
