i got more troubles!
92Sidekick4x4
1456
Spencer Atkinson, 92Sidekick4x4
October 06, 2004, 01:33:51 PM »
ok i got my lift in and all that shit but nwo the fawkign this isnt starting it is just turnin over no gas is gettign to the engine! is there a restart button or some shit that i press i remember reading about this but i cant remember wher eit is.!
please help
my lug nuts require more torque then my engine makes
Speedracer7c
2210
Guess she ain't stock no more!
Re: i got more troubles!
October 06, 2004, 01:36:29 PM »
Did you unplug anything when you raised the body that you forgot to plug back in?
explosivo
3157
I'm in the northern part of that one state.
October 06, 2004, 01:36:49 PM »
Check your lines and make sure you didn't get a kink in your gas lines. :-/
omghi2.us[/url]
Its a ZUKI thing. Doing more with less than less with more.
" -- HotRod
Speedracer7c
2210
Reply #3 on:
October 06, 2004, 01:38:19 PM »
Good call
92Sidekick4x4
1456
Reply #4 on:
October 06, 2004, 01:40:28 PM »
didnt notice nay kinks, plugeed all back in, doe sthe fuel filelr cap have to be on? caus emien is off right nwo and i cant put it on cuz i havnt extended it, with the cap does it creat some kind of pressure for it to start?
Speedracer7c
2210
Reply #5 on:
October 06, 2004, 01:42:19 PM »
is the hose connecteed to anything? I have no clue if it would matter. But maybe the tank needs vacuum or something.....
92Sidekick4x4
1456
Reply #6 on:
October 06, 2004, 01:43:26 PM »
thats what im thinkin liek i wodner if i need the fuel cap on there for it to work?
SpinalTap
Reply #7 on:
October 06, 2004, 01:44:46 PM »
Holy shyte man...slow down and watch what you're typing...its easier to help if we can figure out what you're asking
I'd look around and make sure no wires were pulled off...doesn't the coil have a wire going to ground? Just a thought
wildgoody
8134
67
Reply #8 on:
October 06, 2004, 01:47:46 PM »
Cap is not needed on tank
Check Wires and Fuel lines
Check fuel pump wires, did
you disconnect them or did
they get pulled
Last Edit: October 06, 2004, 01:48:53 PM by wildgoody
92Sidekick4x4
1456
Reply #9 on:
October 06, 2004, 01:55:15 PM »
is ther eno fuel pump reset button? anywhere?
TN_Tracker
1113
Reply #10 on:
October 06, 2004, 01:57:52 PM »
Also check the distributor cap, mine was very close to the firewall during the lifting process and I had to remove one of the plug wires until after the lift was done.
92Sidekick4x4
1456
Reply #11 on:
October 06, 2004, 02:12:39 PM »
any mor esugestions
wildgoody
8134
67
Reply #12 on:
October 06, 2004, 02:38:44 PM »
No resets that I know of
There is a relay in the back
opposite the fuel filler, you get to it
from inside the rear thru the pannel
LilRed
930
3
Reply #13 on:
October 06, 2004, 02:46:25 PM »
That's the darndest thing. My '92 did the same thing after installing a 2" body lift. Turned out to be the ECM on mine so I don't know how it could possibly be related to doing a body lift!
At any rate, can you hear the fuel pump running? Should run for 3 seconds after you turn on the key. Have you tried pouring gas directly in the throttle to see if it will run? If it does, take a look at Mike Hagan's post earlier titled something like "won't start without ether".
92Sidekick4x4
1456
Reply #14 on:
October 06, 2004, 02:52:44 PM »
fack, i replaced my ecm about 2 months ago how coudl this be caused by a body lift?
