i got more troubles!
  • 25 Replies
  • 5386 Views
Offline 92Sidekick4x4
  • 1456
« on: October 06, 2004, 01:33:51 PM »
ok i got my lift in and all that shit but nwo the fawkign this isnt starting it is just turnin over no gas is gettign to the engine! is there a restart button or some shit that i press i remember reading about this but i cant remember wher eit is.!
please help
Offline Speedracer7c
  • 2210
Re: i got more troubles!
« Reply #1 on: October 06, 2004, 01:36:29 PM »
Did you unplug anything when you raised the body that you forgot to plug back in?
Offline explosivo
  • 3157
« Reply #2 on: October 06, 2004, 01:36:49 PM »
Check your lines and make sure you didn't get a kink in your gas lines. :-/
omghi2.us[/url]
  • 2210
« Reply #3 on: October 06, 2004, 01:38:19 PM »
Good call
  • 1456
« Reply #4 on: October 06, 2004, 01:40:28 PM »
didnt notice nay kinks, plugeed all back in, doe sthe fuel filelr cap have to be on? caus emien is off right nwo and i cant put it on cuz i havnt extended it, with the cap does it creat some kind of pressure for it to start?
  • 2210
« Reply #5 on: October 06, 2004, 01:42:19 PM »
is the hose connecteed to anything? I have no clue if it would matter. But maybe the tank needs vacuum or something.....
  • 1456
« Reply #6 on: October 06, 2004, 01:43:26 PM »
thats what im thinkin liek i wodner if i need the fuel cap on there for it to work?
SpinalTap
« Reply #7 on: October 06, 2004, 01:44:46 PM »
Holy shyte man...slow down and watch what you're typing...its easier to help if we can figure out what you're asking ;)
I'd look around and make sure no wires were pulled off...doesn't the coil have a wire going to ground? Just a thought ???
« Reply #8 on: October 06, 2004, 01:47:46 PM »
Cap is not needed on tank
Check Wires and Fuel lines
Check fuel pump wires, did
you disconnect them or did
they get pulled ???
« Last Edit: October 06, 2004, 01:48:53 PM by wildgoody »
  • 1456
« Reply #9 on: October 06, 2004, 01:55:15 PM »
is ther eno fuel pump reset button? anywhere?
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #10 on: October 06, 2004, 01:57:52 PM »
Also check the distributor cap, mine was very close to the firewall during the lifting process and I had to remove one of the plug wires until after the lift was done.
  • 1456
« Reply #11 on: October 06, 2004, 02:12:39 PM »
any mor esugestions
« Reply #12 on: October 06, 2004, 02:38:44 PM »
No resets that I know of
There is a relay in the back
opposite the fuel filler, you get to it
from inside the rear thru the pannel
« Reply #13 on: October 06, 2004, 02:46:25 PM »
That's the darndest thing.  My '92 did the same thing after installing a 2" body lift.  Turned out to be the ECM on mine so I don't know how it could possibly be related to doing a body lift!
   At any rate, can you hear the fuel pump running?  Should run for 3 seconds after you turn on the key.  Have you tried pouring gas directly in the throttle to see if it will run?  If it does, take a look at Mike Hagan's post earlier titled something like "won't start without ether".
  • 1456
« Reply #14 on: October 06, 2004, 02:52:44 PM »
fack, i replaced my ecm about 2 months ago how coudl this be caused by a body lift?
