????? IS THE REAR DRIVE SHAFT THE SAME LENGTH IN..........
SideTrackedInNY
21
May 19, 2010, 07:12:46 PM »
A FOUR DOOR AUTO AS IT IS IN A 5 SPEED?
?? THANKS MATTY D.
wildgoody
8134
67
Re: ????? IS THE REAR DRIVE SHAFT THE SAME LENGTH IN..........
May 19, 2010, 07:17:06 PM »
I think it is, the T-case is bolted to the same place, and that's the
end of the trans assembly
I did a swap from 5 speed to 3 speed auto, but it was a 2 door, seems
like we used the same driveshaft there too
SideTrackedInNY
21
May 19, 2010, 08:13:01 PM »
OK THANKS WILD .....
cj
1276
I drive a really big ATV
Reply #3 on:
May 19, 2010, 08:18:44 PM »
3 spd auto and 5 spd manual are the same but the 4 spd auto should be shorter due to the increased length added to the auto by the overdrive.
SideTrackedInNY
21
Reply #4 on:
May 19, 2010, 08:38:32 PM »
ok thanks cj will have to go over to my lot and measure it i guess...thanks matty d.
Skyhiranger
3734
122
I don't buy, what I can build
Reply #5 on:
May 19, 2010, 09:07:35 PM »
I can tell you for sure that the driveshafts are not the same length.
SideTrackedInNY
21
Reply #6 on:
May 19, 2010, 09:23:32 PM »
thanks again guess i need not measure then....thanks matty d.
