????? IS THE REAR DRIVE SHAFT THE SAME LENGTH IN..........
  • 2234 Views
A FOUR DOOR AUTO AS IT IS IN A 5 SPEED??????  THANKS MATTY D.
Re: ????? IS THE REAR DRIVE SHAFT THE SAME LENGTH IN..........
« Reply #1 on: May 19, 2010, 07:17:06 PM »
I think it is, the T-case is bolted to the same place, and that's the
end of the trans assembly
I did a swap from 5 speed to 3 speed auto, but it was a 2 door, seems
like we used the same driveshaft there too
« Reply #2 on: May 19, 2010, 08:13:01 PM »
OK THANKS WILD .....
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: May 19, 2010, 08:18:44 PM »
3 spd auto and 5 spd manual are the same but the 4 spd auto should be shorter due to the increased length added to the auto by the overdrive.
« Reply #4 on: May 19, 2010, 08:38:32 PM »
ok thanks cj  will have to go over to my lot and measure it i guess...thanks   matty d.
« Reply #5 on: May 19, 2010, 09:07:35 PM »
I can tell you for sure that the driveshafts are not the same length.
« Reply #6 on: May 19, 2010, 09:23:32 PM »
thanks again guess i need not measure then....thanks matty d.
