Just Some Pics of My Junk.......
  • 12 Replies
  • 4422 Views
Offline billj
  • 9
  • I love YaBB 1G - SP1!
« on: September 08, 2003, 07:14:54 AM »
Here are a few pics of my Samurai.  It´s been laid up for the best part of a year after I sucked water into the bottom part of the engine...... :-[
Since I had to rip into it anyways, I decided to swap the motor out for a 1.6 16 valve from a Swift.  The mechanical part was easy, the nightmare has been the electrical wiring.  I STILL CANNOT FIND THE SCHEMATIC FOR THIS ECM!!!!!!!! ???
But slowly I´ll get there........
Other crap done during the downtime:
- full roll cage
- beadlocks for the 35" Swampers
- stinger front bumper with 12000 lb winch
- soft doors
Comments welcome........
Bill
  • 6593
Re: Just Some Pics of My Junk.......
« Reply #1 on: September 08, 2003, 07:28:50 AM »
Bill
For wiring harness to adapt the 1.6L 16 valve to your Samurai, I'd suggest Brent at Trail Tough. 877.789.8547 He can make a plug and play harness for you!
Offline billj
  • 9
« Reply #2 on: September 08, 2003, 07:42:19 AM »
Nope, it´s a 1.6 16 valve from a German market Swift.  Different than anything sold in the States........ ??? :-/
  • 6593
« Reply #3 on: September 08, 2003, 08:36:04 AM »
I noticed the intake looks different. I wonder if you could put the US 16 valve computer, intake, and everything on that engine? OR, it kindo f looks like the fuel injected Samurai/Swift set up with the throttle body. Maybe that would help?
« Last Edit: September 08, 2003, 08:38:11 AM by ebewley »
Offline cajunkick
  • 105
« Reply #4 on: September 08, 2003, 10:57:56 AM »
what is the front grill off of?doesn't look like any samurai i have ever seen.i like it alot.
Offline billj
  • 9
« Reply #5 on: September 08, 2003, 10:26:59 PM »
I could do that, but I´d end up spending a lot of dough......  I went with the swift SPFI engine in the first place because it was a lot cheaper than the 16 valve MPFI out of a Vitara.......
Offline billj
  • 9
« Reply #6 on: September 08, 2003, 10:28:07 PM »
That´s what the front of a 1998 Samurai looks like......... ;D
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #7 on: September 08, 2003, 11:28:42 PM »
YOU MAY CALL IT JUNK...BUT IT LOOKS CAPABLE OF LOTS OF FUN.....AND THATS WHERE IT COUNTS  ;D  MATTY D.
Offline Eonknight
  • 29
« Reply #8 on: September 09, 2003, 02:43:44 AM »
Impressive! ;D
Offline pbgbottle
  • 76
« Reply #9 on: September 09, 2003, 03:31:02 AM »
what about the suspension ,coil's ?? custom or factory i heard there was a year of the sammi that came from factory with coil suspension ,what about the rear are those rear hubs ,i see
                     Jake the snake
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Offline billj
  • 9
« Reply #10 on: September 09, 2003, 03:49:05 AM »
                     Jake the snake
My truck was a factory coily, one of those made in Japan from 1997 to 1999, when Suzuki was retooling / debugging for the introduction of the Jimny.  I bought the Sami new in 1998.
Since that time, I´ve completely redone the suspension and drivetrain from the frame down, new springs, repositioned shocks, new control arms.  there literally exists original NOTHING from the tranny down.  Even the t-case has been swapped out for one from the old-style Samurai to enable the installation of gearing.
The axles are both Dana 30, which for a Zuk is plenty strong, IMHO, especially if you don´t do rocks.  The front is ARB´d, the rear welded.  And therein lies the reason for the locking rear hubs.  When I have to drive on asphalt, I unlock the rear hubs, lock the front ones, put the t-case in 4x4 high and drive around in 4x2 front wheel drive.  Works great!!!!!!! 8)
I´m set up eventually to do a rear steer, but for now, I´ve just locked it straight ahead.  One day I´ll get around to making it operational using a double ended hydraulic cylinder.........
Crabzuki
« Reply #11 on: September 09, 2003, 06:01:20 AM »
billj - at any rate your rig is looking tight, and ready for  a Baja Rally. One quick question tho why rear steer doesn't it turn sharp enough or, do you wish to turn on a dime and get nine cents back? Or perhapse your looking to do some serious rock crawling.  ???
Offline billj
  • 9
« Reply #12 on: September 09, 2003, 06:19:08 AM »
Ha!!!!!!!!  Baja Rally?!?!?  With the gearing, my rig does around 50 MPH, tops........
No real reason to do rear steer, just another project to undertake.  I do all of this for my personal enjoyment, from the design to the fab to the install....... :-*
