Richmond Gear would like to hear from YOU - Vote TODAY!
  • 48 Replies
  • 11958 Views
0 Members and 14 Guests are viewing this topic.
  • 6571
  • 66
« on: September 28, 2007, 03:25:57 PM »
We have been contacted by Richmond Gear to do an informal poll to see which gear sets the Suzuki community would like to see produced. The more people that participate the better for two reasons: first, show them that the Suzuki enthusiasts would like deeper gears for their rides and second, more samples (votes) should help get more realistic percentages. So, Please forward this thread to whomever you think would like to weigh in on the subject.
Here's the url: http://www.zukiworld.com/forum/index.php?topic=19068.0
Thank you, Eric
A little about Richmond - RICHMOND Performance Products are the result of a continuous research and development program combined with state-of-the-art manufacturing capabilities at our plant in Liberty, South Carolina.  RICHMOND is the leading manufacturer of professional quality, hi-performance ring and pinion sets. For over 80 years, the Double Diamond has signified the highest quality gears in the racing industry! The superior quality of RICHMOND Performance Products is a result of continual research and development, outstanding design and state-of-the-art manufacturing. Extensive testing is performed on all Richmond products. Engineered to perform faster and more reliable, our products are winners both at the Daytona 500 and U.S. Nationals for decades!
RICHMOND is proud to offer two series of Powertrax® extreme traction differentials to satisfy the most demanding requirements. Lock-Right is proven for brute force off-road applications. The new Powertrax® system is the premier line that combines the highest degree of traction output with superb street driving characteristics.
RICHMOND's "Bullet Proof" transmissions are packed with power and speed. The superior quality is a result of constant research and development and extensive testing at our Liberty, South Carolina facility. Outstanding engineering design has made the DOUBLE DIAMOND gearing the winner at the track or on the street.
Professional quality and our enthusiastic approach to drivers who demand winning performance are built into every transmission and gear set that carries the RICHMOND name.
« Last Edit: October 03, 2007, 04:23:18 PM by ebewley »
Offline locjaw
  • 2045
  • 22
Re: Richmond Gear would like to hear from YOU - Vote TODAY!
« Reply #1 on: September 28, 2007, 04:10:07 PM »
6.33's hmmmm, is that correct??
that would solve a lot more problems than 5.89's.......... yet cause soooo many  more ;)
« Reply #2 on: September 28, 2007, 04:26:03 PM »
I'd go for the 6.33's ;D
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #3 on: September 28, 2007, 05:21:29 PM »
6.33's, my mouth is watering, but Could the pinion be made strong enough to hold up?
Student of Now Master of Then
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #4 on: September 28, 2007, 07:40:48 PM »
Lower gears from a name brand?  I guess I had better start saving up for a set now.  Add the lower gearsets with some lower transfer case gears and I would be leaning away from doing a Sami doubler setup.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: September 28, 2007, 08:00:53 PM »
I hope that they're looking at offering them for the Kick rear. It would solve a major problem.
« Reply #6 on: September 29, 2007, 06:51:56 AM »
6.33s, I like the sound of those. The 5:83s are still a bit high on my 8V with 33s
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #7 on: September 29, 2007, 10:15:02 AM »
I forgot to mention this but if they do go ahead with any of the above options it would be no good unless the gear sets were available for both front and rear Track-Kick axles.
« Reply #8 on: September 29, 2007, 05:12:24 PM »
As we continue to build these rides bigger and better than ever before, the need for low gearing is a MUST!!!!!!
Thanks Richmond!!!!
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #9 on: September 30, 2007, 09:56:56 PM »
My vote is for the 6.33:1 gears.  I am running 33's and would love to run 35's.  PLEASE MAKE THEM!! :D
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
« Reply #10 on: October 01, 2007, 06:58:45 AM »
Well, since many Zooks run 5.12s stock, 6.33s are the real option for them.
Eric -
These gonna be 12 bolt rear, 10 bolt rear or both?
  • 6571
  • 66
« Reply #11 on: October 01, 2007, 08:51:26 AM »
Eric -
That is definitely something to pass along. That there are some options out there like the 10 bolt 12 bolt deal on the 7.5" ring and also, like someone mentioned, a 7.0" ring & pinion for the fronts...
« Reply #12 on: October 01, 2007, 12:56:10 PM »
If they could make them work...  It would certainly help for putting larger tires on manual trackers.  :)
Offline cj
  • 1276
« Reply #13 on: October 01, 2007, 04:24:50 PM »
Eric -
Given that the bulk of Kicks are most likely to be 12 bolt rear and the GV's are also 12 bolt then from a volume point of view that would be the logical choice for a rear R&P. Those with a 10 bolt can upgrade to a 12 bolt carrier if needed, at least there would an option. Obviously there is no point making a rear without a matching front ratio available too. The fronts will also fit the Sammi's so volume isn't an issue there but they already have so many gearing solutions available that I really hope that Richmond are looking at this for the Kicks and GV's. I know I will definitely be buying a 12 bolt 5.83 if/when they ever become available as I have a lonely 5.83 front sitting here waiting to be used and a 6.33 would be the next choice for me.
« Reply #14 on: October 02, 2007, 10:07:30 AM »
Eric -
Pass along that 12 bolts are all that needs to be produced.  Also, to machine the 7" rings so that they work in the Kicker, and in the Sammy without cans and spacers.
