Richmond Gear would like to hear from YOU - Vote TODAY!
  • 48 Replies
  • 13695 Views
mudfkr
Re: Richmond Gear would like to hear from YOU - Vote TODAY!
« Reply #15 on: October 02, 2007, 07:07:23 PM »
I know I will definitely be buying a 12 bolt 5.83 if/when they ever become available as I have a lonely 5.83 front sitting here waiting to be used and a 6.33 would be the next choice for me.
I'll sell ya my 5.83's if they ever make the 6.33's  ;D
« Reply #16 on: October 02, 2007, 08:25:05 PM »
5.83 are ahead????
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #17 on: October 03, 2007, 07:20:54 AM »
I placed my vote!
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline SnoFalls
  • 1358
« Reply #18 on: October 03, 2007, 01:47:24 PM »
I'm tryin to figure out why someone would vote for 4.57???
4.62 is already available (just call hawk or trailtough and you can get 4.62 for either a trac/kick or a sami)
Offline riberware
« Reply #19 on: October 03, 2007, 05:51:57 PM »
I want those 5.83:1 for the rear of my Sidekick, Im runnin 33" Boggers with stock R&Ps and a 4.24:1 T-case. I really miss my 5th on highways... ;)
Offline riberware
« Reply #20 on: October 03, 2007, 06:13:43 PM »
6.33:1 that's absurd, the pinion will be so small and really easy to break.
Have you seen a Samurai 5.83:1 pinion... it looks like chicken drumsticks
Offline BlueRidgeRunner
  • Trail tested not trail rated.
« Reply #21 on: October 03, 2007, 07:40:47 PM »
6.33's, my mouth is watering, but Could the pinion be made strong enough to hold up?
Ditto on his question.
NAME A TRAIL at UWHARRIE for ART![/url]
MSG. ART LILLEY MEMORIAL DECALS[/url]
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #22 on: October 03, 2007, 07:53:00 PM »
Yeah...that stuck in my mind...lots of teeth for itsy bitsy ring and pinion.
I voted for the two 5.xx's as both are good choices for IFS Suzi's while also being VERY low for Sami owners.
exopar
« Reply #23 on: October 03, 2007, 09:37:09 PM »
Anithing bigger than 4.88 whould be a hit on my opinion.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #24 on: October 03, 2007, 09:53:28 PM »
I'm liking the possibilities of the 6.33's... 8)
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #25 on: October 03, 2007, 09:54:06 PM »
Kicks have the following available
Ratio Ring Pinion
4.3 : 43/ 10
4.625 : 37/ 8
4.785 : 39/ 8
5.125 : 41/ 8
5.38 : 43/8
5.62 : ?
5.83 : 35/6 Calmini
A 6.33 would be 38/6
Design and manufacture are important. Just because a ratio is say 5.83 it doesn't mean it is weaker than a 5.38
Offline Madraoulas
  • 11
« Reply #26 on: October 04, 2007, 12:49:17 AM »
Nice to hear that new r&p is going to produced for Vitara and GV
I've already have 5.38 and I found them by second-hand here in zukiworld and I was very lucky!..
I say that because there are TOO MANY zuki enthusiasts here in GREECE that would like to have gears (bigger than 5.12)
so keep going on
P.S...5.43...must correct to 5.38 I think
« Last Edit: October 04, 2007, 02:03:25 AM by Madraoulas »
Vitara 1.6 2d '91, 2''1/2 lift (OME shocks + Suplex coil-springs), 235/75/15 Maxxis 8060,full system exhaust by Calmini, K&N filter, 15x7 alloys zero offset
Lord S
« Reply #27 on: October 04, 2007, 03:30:51 AM »
Personally I would like to see a conversion that lowers the Low Range gearing, but leaves the high range as normal.
Especailly in a Vitara (or whatever the yanks call them)
Offline aftermarket4x4
  • 145
  • ZUKIWORLD
« Reply #28 on: October 04, 2007, 04:26:04 AM »
Here you go:
http://www.lowrangeoffroad.com/kickdrivetrain.htm
Sean
« Reply #29 on: October 04, 2007, 04:40:23 AM »
No smaller than a 5.83, except 2 extra teeth on the ring.
