still problems with x-90 power windows. is this a good idea to try ?
  • 3201 Views
Offline MARTYRD
  • 16
guys still have problems with power windows on my 1996 x-90. they are really slow and makeing a heck of noise. thank god there in the up postion. i think i need new window motors. i have not taken the door covers off yet.  if so i would not know how to fix them any way. i called my suzuki dealer 286.00 each for a window motor plus 125.00 labor EACH. i need both sides fixed.  the sidekick motors would not fit he said. would it be easier and cheaper just to convert them over to hand crank windows ? i dont have alot of money to spend. if i have to cut a hole in door that is ok i can patch it up with something. i need the doors to roll down.  does any one know were i could get some window motors and the other stuff that would make doors go up ? thanks. marty in IL.
Offline ToyYoda
  • 226
Re: still problems with x-90 power windows. is this a good idea to try ?
« Reply #1 on: February 08, 2006, 09:21:46 PM »
MartyRD, I just bought a 1996 X90 & it too has the same slow windows on both doors. I own a service shop that only works on asian SUV's & will be checking it out in the next few days.I'll check back with an answer soon if you don't get one before then.   ;D
Offline MARTYRD
  • 16
« Reply #2 on: February 08, 2006, 11:45:56 PM »
WILL I FINALLY BROKE DOWN AND BOUGHT ANOTHER WINDOW MOTOR FOR DRIVERS SIDE.  JUNK YARD OUT EAST HAD ONE.  300.00 FOR AND MY BODY SHOP PUT IT IN.  IF MY MONEY GETS GREEN I STILL NEED ONE FOR PASSEGER SIDE. MARTY
Jayzuki
« Reply #3 on: February 09, 2006, 12:05:00 AM »
So how does the window work now?
Offline MARTYRD
  • 16
« Reply #4 on: February 09, 2006, 12:09:00 AM »
WORKS BETTER THAN IT DID . IT WAS GRINDING BAD. SHOT.  STILL NOT AS FAST AS THE BUICK. BUT IT WORKS. MARTY
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #5 on: February 09, 2006, 05:25:57 AM »
What am I missing here?  $300 for a junkyard window motor?????  or $300 total, installed?
Jeez.. that's high, isn't it...
Offline jzap
  • 515
  • How difficult can it be?
« Reply #6 on: February 09, 2006, 05:30:47 AM »
I would bet that some cleaning and lubrication in strategic locations would do the trick...
Also, if the X-90 is designed like every other vehicle I have ever worked on, the designers try to optimize the design for cost reduction purposes.  So, I would expect the manual window mechanism to mount to the same mounting points as the power mechanism...   ...but that is just a mechanical engineer's guess...
Jim Z.
66 Apache camper
Offline MARTYRD
  • 16
« Reply #7 on: February 09, 2006, 11:20:05 AM »
cost me 176.00 for window motor from junk yard. 15.00 to ship. 2 hours labor from body shop to put it in. total 300.00. marty
