How many miles can a sidekick get on it?
  • 31 Replies
  • 8400 Views
95XL7
Re: How many miles can a sidekick get on it?
« Reply #15 on: February 11, 2006, 08:05:24 PM »
My 1.6 had only 12,000 miles before i got sick of it and went V-6,tracker now has 16,500 original miles and 17000 on the V-6. ;D
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #16 on: February 11, 2006, 09:34:28 PM »
Daily Driver: '00 Tracker 2.0 146,000 miles
Trail Rig: '96 Tracker 1.6 128,000 miles
I don't think either one are near the end of their life. 8)
Offline da_tub
  • 307
  • oops...can we still back up>?
« Reply #17 on: February 11, 2006, 09:39:31 PM »
91 four door..265 and some change..and still purrin like a kitten in town and bouncin like tigger in the bush!!( ;D)
91 four door ,and some stuff
Offline purpletracker
  • 115
« Reply #18 on: February 11, 2006, 10:35:10 PM »
just bought with 225k miles .run  strong ,no smoke or knock
Offline urbanwheeler
  • 696
« Reply #19 on: February 12, 2006, 12:35:42 AM »
Awesome, I would have never guessed that these things had the longevity comparable to a toyota truck ;D ;D ;D. I am happy to know that mine has plenty of life left in it. It now has a little over 126,000 on it, with a JDM motor that is supposedly in the 50,000 mile range. It is also good to know that the drive train will last 2 bodys ;D. The only thing I have left to do on mine is fix the engine surging problem that occurs when the headlights are on, and possibly rebuild the transmission(eventually, mostly because 2nd is a little grindy, and 5th makes an interesting growl, screech wirr noise, but not incredibly loud (it is probably one of the bearings)).
Runnin' it stock with 225/75R15s and an unmodified 8valve TBI motor (I need a doug thoroley header and a cam) (more power) (1.6 liters of madness) (vroom + sewing machine sounds)
Offline Frank84
  • 176
« Reply #20 on: February 12, 2006, 06:44:15 PM »
glad to hear the newer 2.0's will last as well TN_Tracker,  my '01 2.0 has only got 73k on it and runs perfect
anyone else with high miles on a 2.0?
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Shilly
« Reply #21 on: February 12, 2006, 06:59:11 PM »
My '91 1.6 has 160K miles on it and it increases by 84 per day because of my commute to work.  Uses a little oil, maybe a qt every 3000 miles or so. It's my DD and I'm hoping to use it on a trip to Ohio (from SC) this summer. It's like a 4WD Visa card, because it takes me everywhere I want to go   ;D
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #22 on: February 12, 2006, 08:39:25 PM »
My 1.6 was in a 89 auto 4 speed tracker all its life... it seemed tired when i first put it in.. but after running the crap out of it for about a week its almost like the rings re seated and it feels like a low K motor.. im quite happy with it for a 300 K 4 cyl... I can spin my 33's on dry pavement :P and it hauls along at 100 K quite nicely
Sj410 Full exo, Locked, race buckets, 5 point
85.5 LWB sami, Toy axles, locked rear, CJ/RUF, warn 8000, 33's
Offline wedge
  • 38
« Reply #23 on: February 12, 2006, 10:33:20 PM »
my 89 tracker has 57,000, but not sure how many times it has actually kicked over the top and started over again. ::)  got it and it hadn't been registerd since 92 when it had 17,000.  but it puffs smoke on a cold morning.  and the fan clutch bit the dust.
Offline bbagwell
  • 278
« Reply #24 on: February 13, 2006, 08:26:26 AM »
168,000 never even had the valve cover off.  Just a puff of smoke when you first start it in the morning.
2002 Suzuki Grand Vitara
1983 Toyota PU
« Reply #25 on: February 13, 2006, 08:31:58 AM »
Bagwell, you might want to take the
valve cover off and adjust the valves.
I did the same thing, and lost the
exhaust valves, and needed a valve job
at 200,000 miles, which was the beginning
of the end of the engines life.
New valves killed the rings, and at 240,000
I needed a rebuild
Offline sutas
  • 20
« Reply #26 on: February 13, 2006, 08:54:08 AM »
...5th makes an interesting growl, screech wirr noise, but not incredibly loud (it is probably one of the bearings)).
I have the same issue with 5th.  Not sure exactly what it is but you may be correct.  I did see something on that topic in the forum though.
'94 Tracker 235/75 15 Goodyear MT/R's 1" wheel spacers.  more to come...
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #27 on: February 13, 2006, 09:35:07 AM »
Goody, what is the interval for valve adjustment?
Mine taps a bit when cold.. but quiets down when warm..   gotta be valves.. nothing serious..
no smoke.
I guess I should adjust the lash huh?  and go ahead a put a fresh timing belt on too..
I guess this would be a good time to ask.. is this a non-interference engine? I mean, when a timing belt breaks, does it take the valves out with it?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #28 on: February 13, 2006, 01:56:20 PM »
My poor 4-door has been through hell.
1995 - I'm the original owner.
172,000 miles.
TWO teenagers learned how to drive on it.  Manual transmission.  In the mountains.  Poor baby.  Then last Easter (during EJS) my son had his car stolen.  "Dad, can I borrow your 4-door?"  I got it back at Thanksgiving.  It had been BADLY abused.  Oil was at least 2 quarts low.  Sounds like one rod may be knocking.  *sigh*
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #29 on: February 13, 2006, 06:13:15 PM »
Valves should be adjusted, or at least checked
every 15,000 miles. These valves seem to tighten
as they wear, which is the problem, if they loostened
they would just make noise.
The 8V and 16V are non interference engines, tho
there are some differing oppinions, in my tests, both
checked out as non.
