Sami Lift Help (driveline)
  • 1973 Views
Offline Havoc_Smirf
  • 21
  • HavocOffroad.com
    • HavocOffrad
« on: February 14, 2006, 11:32:35 AM »
I already have a SPOA lift on my Sami and running a 32" TSL.  I'm in desperate need of new leaf springs but was wondering if I got the rancho springs with the 1.5" lift built in would that mess up my driveline?  I'm already using the calmini driveshaft spacers.  Thanks for the help!
1988 Suzuki Samurai - 6" lift, 28" Thornturds, Welded rear, Rear 3rd member up front w/ Calmini 26 spline axles shafts w/ EZ-Locker, Full-Cage, Running on Propane!
1999 F250 - Fabtech lift, 37" SSR, Autometer Guages, Edge Evolution
Offline prairie_dog
  • 234
  • 85/413 tin top
Re: Sami Lift Help (driveline)
« Reply #1 on: February 14, 2006, 10:44:19 PM »
 I got the spoa lift on 31's and had to use a 2 degree shim to fix the slight vibration, if you didn't have a vib before you might after the lifted springs.
  The back is usually the problem ( shorter shaft = more extreme angles )
 The shims are 5-15 bucks a pair ( easy fix )
 Steve. :)
Offline Ronzuki
  • 261
  • What's a Samurai?
« Reply #2 on: February 15, 2006, 06:42:06 AM »
I've got the 1.5" lift ranchos on all 4 corners.  w/ that much lift, you're getting close to binding the stock shaft at full droop.  I put new Arizona Driveline shafts (1310 joints) in when I did my lift. As far as vibes go, I've got slight vibes from the rear driveline under hard accel in 2nd gear, no biggie.
'91, RRO Bolt-On SPO, 32" BFG Muds, 2" BS U.S. Wheels, Breeeze CO, Neon Seats, 5.8:1 T-Case, TT Mighty Kong Bucket, 1.5" RUF, 1.5" Rears, DT Shocks, RRO Sliders ,Rear DetroitEZ, OBA,Celica PS
RCrocs Team 509
Offline aftermarket4x4
  • 145
  • ZUKIWORLD
« Reply #3 on: February 15, 2006, 08:01:16 AM »
Your diveline will be fine with 1.5" lift Rancho's. No need for big $$$ D-shafts unless you have a ton more lift than that and even then you can clearance the U-joint knuckles so that they do not touch. Bolt the Rancho's on and go wheeling!
Sean
