Sidekick Master Cylnder in a Samurai
  • 2483 Views
Offline dsumers
  • 72
« on: March 15, 2006, 06:36:08 PM »
Seems like I have read somewhere that you could install a sidekick master cylnder in a samurai and is a direct bolt in ;D.  I cant seem to find any links on this ???.  Has anyone done this?  If so, would like to know how it worked out and if it was just a simple bolt in.  I'm running Dana 44 axles with large 11" drums in back and discs up front.  I used to run drums all the way around with excellent brakes  :).  After changing over to disc up front, pedal has always been soft :-[.  So, if it is possible to use the sidekick master cylnder, I figured it is bigger and would work better.  Any information would be greatly appreciated.  Thanks
Offline robe2conoby
  • 8
  • drive it like u stole it!!!!!!!!!!!!! !!
    • Nckrawlers
Re: Sidekick Master Cylnder in a Samurai
« Reply #1 on: March 15, 2006, 08:14:51 PM »
I run 44's out of a 78 waggy disk/drum  My config is ford ranger master cyclinder to a waggy prop valve to the breaks, This stops 35's hard locks up all 4 if needed..
And yes it's a direct swap in, the only mod is to extend the push rod in the booster to get full throw to the m/c
Hope this helps
Offline dsumers
  • 72
« Reply #2 on: March 15, 2006, 09:09:25 PM »
What is a direct bolt in the sidekick, or the ranger ???.  I will assume the kick, which rod do you use the sammy or the kick?  Do you know if this is better than the sammy master?  Thanks for the reply.
Offline billybob
  • 23
« Reply #3 on: March 15, 2006, 10:51:08 PM »
Hey D...
I can tell you what I know... Sami M/C is 7/8" with 2 brakelines, the track/kick (95-96) is also 7/8" BUT has a crossover brake system (better) that has 5 brakelines, one of which goes to a modulator for the rear cylinders. What all this means is that Yes, the M/C will bolt straight in BUT you need to route 3 new brakelines and a rear modulator.... when done this system would be superior to the sami OE set-up
billybob_CA
« Reply #4 on: March 16, 2006, 04:51:11 AM »
I don't think you need to mess around with the modulator and lines. There are two outputs for the front you could just block off one of the front outlets with a hex bolt and copper washer. If you rate the mod then maybe run the sepearte lines to the front. Not all Track/Kick master cylinders are 7/8" some are the same size as a Sammy (can't remember the exact measurement)
Offline dsumers
  • 72
« Reply #5 on: March 16, 2006, 02:45:28 PM »
Thanks for the reply's, sounds like they are about the same and probaly not worth the hassle of swapping.  Is there any other master cylnders out there that would be a large increase, with little effort to install?   Thanks, again
« Reply #6 on: March 17, 2006, 12:57:54 PM »
I have heard that some Subaru or Firebird m/cs fit the Jap models. My Vit had Lucas Girling brakes and I used a Rover master cylinder.
