Body Lift Pics
  • 33 Replies
  • 9063 Views
0 Members and 13 Guests are viewing this topic.
Offline 2K1USGV
  • 218
Body Lift Pics
« on: March 22, 2006, 01:18:54 PM »
So I finished the body lift and here are teh after pics. I was going to take before pics, but my camera batteries died and I didn't want to wait to get new ones before starting. This is the RRO 2" body lift. Unlike the XL7, I didn not have the modyfy the blocks at all.
Offline the_maplebar
  • 466
Re: Body Lift Pics
« Reply #1 on: March 22, 2006, 03:04:50 PM »
Good to know.  So what did you do with the bumpers?  It looks like you trimmed the bottom off of the bumper covers front and rear, anything else?
Man that gas tank hangs low.  Makes you really wish you could do the gas tank lift ;)
Offline 2K1USGV
  • 218
Re: Body Lift Pics
« Reply #2 on: March 22, 2006, 03:27:38 PM »
There are a few things to know before doing this.
1-detatch the brake line bracket from the body ont he passangers side.
2-The evap canister lines need to be lengthenes, I got some 1/4 tubing about 8 inches, it's only short by about 2 inches, but detach it when lifting becuase it will have far to stretch.
3-Detatch rear parking brake lines from frame in the center under the GV. There are actually 2 more points to unbolt on the axle as well, one on each side.
4-Ubbolt the fulel filler hose, I  pulled in a little and put the gas cap back on to keep the gas smell contained.
5-disconnect the front compressor hoses that go tot he compressor in the front bumper.
I decided to trim the bumpers rather than cut into the bumper support. I will put a skid plate in the front and perhaps fab up a pre-runner bar. As you can tel the rear bumper only needs minor trimming to fit over the bumper. I decided to trim the bumpers and keep the stock mounting points for everything. I will also fab up a rear skid plat to cover the gas tank.
Oh, and remember to jack up both front tires all the way off the ground before removing/reinstalling the Strutt brace. When fully lowered the struts go towards each other, when lifted the spread apart. The strut bar is the length of the struts spread apart. Just an FYI.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Body Lift Pics
« Reply #3 on: March 22, 2006, 04:25:50 PM »
Looks good more pics under neath
Nice S2k  ;D
01 GRAND VITARA
Offline 2K1USGV
  • 218
Re: Body Lift Pics
« Reply #4 on: March 22, 2006, 04:29:28 PM »
Thanks,
The S2k is currently my daily driver while work is done on the GV, most of the time it's the other way around :) . I'll get more pics of under the truck tomorrow.
Offline JDMCRX
  • 1110
Re: Body Lift Pics
« Reply #5 on: March 22, 2006, 04:50:56 PM »
Coo how u like that F20 lol pulls not to bad eh  :P id run ya
01 GRAND VITARA
Offline 2K1USGV
  • 218
Re: Body Lift Pics
« Reply #6 on: March 22, 2006, 04:55:47 PM »
Yeah, it pulls pretty well with the Vortech supercharger and aftercooler :)
Offline JDMCRX
  • 1110
Re: Body Lift Pics
« Reply #7 on: March 22, 2006, 05:45:17 PM »
Fuck now we have a challange for my boosted EL
01 GRAND VITARA
  • 466
Re: Body Lift Pics
« Reply #8 on: March 23, 2006, 06:30:51 AM »
hmmm.... good to know.  I removed mine to examine it and think about modifying it, but getting it back on was a PITA.  Now I know why  ::)
Offline 2K1USGV
  • 218
Re: Body Lift Pics
« Reply #9 on: March 23, 2006, 07:19:14 AM »
Yeah, I noticed that if you use strut spacers and leave the strutt bar out, you're most likely loosing 1/2" or more lift becase the front saggs. The Strut bar is also there to keep the struts in the position/angle. With it removed the weight of the front pushes down on the suspemsion and spreads the bottom of the suspension apart.
Offline JDMCRX
  • 1110
Re: Body Lift Pics
« Reply #10 on: March 23, 2006, 09:13:24 AM »
U refering to my lift? My truck has the strut brace init. i did not notice any difference at all.Nor did CE1 2NR but either way i would put the brace in there it helps on all upper macpherson strut Cars and trucks. U just cut 25mm out of it thats all.
Yeah i use strut spacers but also have a 1.5" spacers for the strut bar but u need to cut the strut brace. i could prevent the cutting of the strut brace but i would have to make a alum plate and i know people would not be willing to pay for it so cutting it is cheap. Muffler shop will charge u $20 on a bad day max
josh
01 GRAND VITARA
Offline 2K1USGV
  • 218
Re: Body Lift Pics
« Reply #11 on: March 23, 2006, 09:18:06 AM »
You might not notice a difference becuase you put the spring spacers in. But I can guarantee you that if you pu the strut brace back in, you will go up at least a half inch in the front. The way the front suspension works is as you know you get 2" of lift from a 1.5" or 1.17" spacer. so what I'm saying is that if you currently have a 1.75" spacer int he front and a 2" spacer in the rear to make it level, with the strut brace you might only need a 1.5" spacer to make it level with a 2" rear spacer.
Offline CE1_2NR
  • 21
  • 2001 GV 4x4
    • Accordingly Done
Re: Body Lift Pics
« Reply #12 on: March 23, 2006, 03:28:58 PM »
This reminds me Josh. When are we doing the strut bar? I have this Monday off.
I'd rather be a Dictator than a Dicktaster.....
Offline JDMCRX
  • 1110
Re: Body Lift Pics
« Reply #13 on: March 23, 2006, 08:00:56 PM »
We will see i have some crap to do RRR im not even gonna comment on what it is.
The bar made no difference on my lift at all that i noticed before and after. the strut towers caving in would only cause negative camber.
josh
01 GRAND VITARA
Offline JDMCRX
  • 1110
Re: Body Lift Pics
« Reply #14 on: March 29, 2006, 03:19:33 PM »
How much work did it look to lift up the rear bumper rienforcement?
01 GRAND VITARA
