Front axle shafts????HELP!!!!!
  • 2282 Views
Offline hobgoblin
  • 224
« on: March 31, 2006, 11:13:12 PM »
Hello All,
I need to find two front drivers side axle shafts...I'm widening my front end and thought I could make a spacer....But after cutting it out,drilling it...It will not work...The CV axle has to set in the spacer etc...So If any on out there has 1 or 2 let me know ASAP. I don't care if they are bend,striped,broken,rusted,etc. All I need is the 3 bolt flanges....Only other thing is take to machine shop and have it turned on a lathe$$$$$$.  PLEASE HELP....I know some one out there has some stripped ones.....
Later Tom K.
Offline hobgoblin
  • 224
Re: Front axle shafts????HELP!!!!!
« Reply #1 on: April 01, 2006, 03:18:07 PM »
Hello All,
Now come on I know someone out there has some....
Later Tom K.
« Reply #2 on: April 01, 2006, 08:22:25 PM »
I'm hoarding them, ALL of them
Muhuhahaha   ;D
BTW you only need one of them the center
the CV axle, the bulk of the spacer can be
whatever, steel if you want to weld the flange
the the spacer, I had a spacer made of aluminum,
cost me about $50 a few years ago.
Offline hobgoblin
  • 224
« Reply #3 on: April 01, 2006, 09:13:13 PM »
Muhuhahaha   ;D
Yep I know...But two would make it easy.....I think I'm going to get a holesaw and cut a 3" hole in 1/8" plate and weld that to "MY SPACER" What is your spacer thickness??? This thing is eating lots of money now.....LOTS!!!! My 33's are rubbing the frame...So I'm doing the Hagen frt end mod...Got 1 extra axle...There where 2 on e-bay....I only got one...Should have got the other also...It was a 26 spline...but to cut it up who cares...
Later,Tom K.
« Reply #4 on: April 01, 2006, 10:16:21 PM »
My spacer is 1" thick aluminum,
lathe turned
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: April 01, 2006, 11:03:36 PM »
Im pretty sure I have a couple more. I could cut off the flanges and ship on Monday if you cant find any locally.
Mike
Offline hobgoblin
  • 224
« Reply #6 on: April 01, 2006, 11:13:20 PM »
Mike
Great!!! I owe you big time...I was hoping you would chime in and set me stright....
I'll PM you!!! Thanks Mike your a life saver!!!
Later Tom K.
