How to remove this???
  • 11 Replies
  • 2787 Views
Offline arkangel
  • 33
  • 2" Coil Spacers Procomp Shocks Zukis rules!
« on: April 07, 2006, 09:09:19 AM »
Hi guys,
I really appologize because I don't know how to call this piece of the body...  :-\
The question here is HOW to remove this piece of the body??
I tried some time ago I wasn't able to remove it beacuse there's some kind of spot-welded parts here?
Any comment would be appreciated.
BR,
Luis Nassiff
'98 Suzuki-Chevrolet Sidekick-Vitara
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: How to remove this???
« Reply #1 on: April 07, 2006, 10:06:24 AM »
It's actually part of the fender.
      Kevin
Offline chrisvitarasport94
  • 228
« Reply #2 on: April 07, 2006, 10:23:42 AM »
if you really want to remove it, (and why?) take the whole wing off - it's easy!  first scribe some line-it -up -again - marks, then remove the bolts on the top edge and inside the top of the door shut,  a screw under the headlight lower outer corner from the bumper lip upwards, and a bolt and captive nut on the lower edge near the sill behind any plastic trim ( careful!)  remember to carefully prise out one line of the plastic inner arch clips ( cheap to replace) and lift it off
Offline arkangel
  • 33
« Reply #3 on: April 07, 2006, 11:45:41 AM »
Ok now I have a better Idea.... I thought it was a single piece separated from the fender...
I was planning to run some wires from VHF/UHF antennas on the roof rack and thought it was easier to remove so the cables can be organized...
Also I was planning to install an antenna support between that piece and the fender but they're one whole piece  :-\
thanks
Luis Nassiff
« Reply #4 on: April 07, 2006, 11:57:57 AM »
A pair of tin snips and it can
be removed from the fender.
I have a light mounted on mine
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #5 on: April 07, 2006, 01:39:16 PM »
Thinking Snorkel??
Cut off saw = friend
Offline arkangel
  • 33
« Reply #6 on: April 07, 2006, 02:28:56 PM »
 :o how did u heard bout my plans to do a home made snorkel  ;)
The inmediate plans are installing the antennas, but maybe a snorkel can be in my way soon  ;D
Luis Nassiff
Offline BigPig
  • 276
« Reply #7 on: April 07, 2006, 03:24:32 PM »
That is what I was thinking about doing to run a snorkel.  If you do it can you put up pics?
'89 Sidekick w/ 4.5" of lift.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: April 07, 2006, 03:42:21 PM »
How do you reattach it after the snipping? ???  Does it affect the rigidity of the fender?
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #9 on: April 07, 2006, 05:50:07 PM »
You can JUST see where I cut mine off to do the snorkal. There's 2 bolts holding it on plus a couple of spot weld type things. I took the fender off, and used a sawzall to cut the welded part off, but still leave all of the fender intact. Was very easy to do. there holes already from the stock intact crap, so I ran a piece of (I think) 2" tubing down thru there and ran a 90* elbow to capture the air. Works well and holds upto highway speeds.  8)
« Reply #10 on: April 07, 2006, 06:53:25 PM »
It's got it's own 2 bolts, just bolt it back on
Offline arkangel
  • 33
« Reply #11 on: April 08, 2006, 07:02:48 PM »
Chief, any chance to take a closer look?
I have experience doing home made snorkels, I'll post a pic of my old toy truck.
I still have a Safari Snorkel AirRam so I just need some PVC, hose, glue and paint  ;)
Luis Nassiff
