1989-1998 Wheels
  • 11 Replies
  • 4009 Views
Jayzuki
1989-1998 Wheels
« on: May 07, 2006, 11:23:52 PM »
Is it true that all the 1ST GENERATION OEM Sidekick wheels are interchangeable on model years 1989-1998? I was wondering if I could put 2002 OEM Vitara wheels on a 1990?
« Last Edit: May 08, 2006, 12:16:25 AM by Jayzuki »
Offline Carnage
  • 2453
Re: 1989-1998 Wheels
« Reply #1 on: May 08, 2006, 12:02:30 AM »
shouldnt have any problems
« Reply #2 on: May 08, 2006, 03:18:07 PM »
Well actually.I beleive the newer ones (GVs) are running 16"inch wheels.
Offline Carnage
  • 2453
« Reply #3 on: May 08, 2006, 03:35:06 PM »
i dont understand why 16s should be problematic
« Reply #4 on: May 08, 2006, 03:39:20 PM »
They're 16s to fit over bigger calipers.
i've heard people complaining that they can't find 15s for their GV on the GV board (here)
Offline Carnage
  • 2453
« Reply #5 on: May 08, 2006, 03:43:00 PM »
ah... i getcha
« Reply #6 on: May 08, 2006, 05:23:44 PM »
ah... i getcha
But then again. I could be wrong. I was thinking newer GVs (99 and up)
Offline Maroon Monsoon
  • 876
« Reply #7 on: May 08, 2006, 05:50:28 PM »
yea, 99 and up are 16's and really hard to fit 15's on. only 1 person I know of on here did it and I think he needed wheel spacers and had to shave down the brake caliper because where the wheel sits against the brake rotor is only about an 8th of an inch beyond the part that the caliper grips... I don't think just any 16 that's the same offset and 5 on 5.5 bolt pattern fits a GV either because of the wierdness there... I do believe the non-grand vitaras that are 2nd gen have an offset that sits closer to the vehicle and more than likely smaller brake calipers
but yea, you can probably fit any suzuki rim on a 1st gen kick/vitara/escudo/tracker
man these things have allot of names
Jayzuki
« Reply #8 on: May 08, 2006, 07:20:04 PM »
Well its good to know I can add a nice set of factory Suzuki wheels to my Hardtop, which will most likely be a 1990-1992. If 1998 is the last year of the 15's then I will try and find a set from a wrecker, will look good :-* Just like Jeep's, can interchange wheels between most models and years. Its great.
Offline Carnage
  • 2453
« Reply #9 on: May 08, 2006, 07:59:18 PM »
well thats what he was askin...
02 vitara wheels should hook right up to a 90
« Reply #10 on: May 08, 2006, 08:04:43 PM »
Well DUH!,
I was thinking the other way around, Don't know why.
Oooops
That has been one of my thoughts B-4.
Sometimes ya can miss the details. :P ;D
Offline Carnage
  • 2453
« Reply #11 on: May 08, 2006, 08:15:31 PM »
 8)
