4wheel drive question
  • 11 Replies
  • 3783 Views
Offline Dark Negotiator
  • 24
  • The Infamous
    • MySpace
« on: May 21, 2006, 07:16:59 PM »
Today I just ran a 2.5 trail in my stock 95 tracker, made it up and back just fine but it kept slipping out of 4wheel drive. I ended up having to hold the shifter foward the whole time to make sure it wouldnt pop back into neutral. Is there anything I can do to stop this from happening?
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: 4wheel drive question
« Reply #1 on: May 21, 2006, 09:33:35 PM »
Yeah, check and make sure the floor or shift boot on the transfer case lever isn't blocking the movement of the lever. My guess would be the boot or the floor itself is hitting the lever and is not allowing it to stay in place...
  • 24
  • The Infamous
    • MySpace
« Reply #2 on: May 21, 2006, 10:45:11 PM »
I dont get it, how can the floor be hitting it?
« Reply #3 on: May 21, 2006, 11:14:52 PM »
A bad T-case mount can let the T-case
fall and that will cause the lever to hit
the body.
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #4 on: May 21, 2006, 11:44:36 PM »
floor = transmission tunnel
when you put it in 4 lo, the shifter is forwards, and may hit on the edge of the transmission tunnel hole where the shifter goes through to the gear box.
even if the shifter doesnt hit the tunner or anything when stationary, when you are driving, or under load, the engine and gearbox will move due to torque, and the movement may be enough for the shifter to hit enough to pop back out.
do you have any body lift? are your engine and gearbox/transfer mounts all good still?
if all the mounts are still good, you can take the shifter out of the transfer, put it in a vice, and bend it backwards a tiny bit so it clears.
and as mentioned already, try checking the shifter boot also. this may be bunching up when in 4 lo and pushing the shifter back.
  • 24
  • The Infamous
    • MySpace
« Reply #5 on: July 16, 2006, 10:14:27 PM »
what exavtly should I do then?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #6 on: July 17, 2006, 04:51:24 AM »
Here are your choices:
1) Take your truck to the dealer and have them fix it.
2) Go to the local library and check out a Chiltons' or Haynes manual and study the transfer case section to get a better idea of how your truck is put together.  Re-read the above posts.  Check under your truck and/or remove your t-case shifter boot and examine the components for damage or wear.
3) Sell your Tracker and get a Ford Focus.
It is Monday.  Which means it is "Why do some folks seem to think that the world owes them an Infinite HandHolding Ticket?" day.
Expand your mind!  Get dirty!  Dig into your truck and figure out what's going on and fix it!
You'll get the satisfaction of being able to laugh out loud every time you drive by the  Chevrolet dealer because YOU FIXED IT!
Rebuilding my Samurai rear suspension/dricvetrain on my own, I remain
Slightly grumpy and at work...
Ack
  • 24
  • The Infamous
    • MySpace
« Reply #7 on: July 17, 2006, 01:43:57 PM »
well I gess ill get a book lol
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #8 on: July 17, 2006, 01:56:48 PM »
Normally you'll have problems with the floor, or tranny tunnel, if you've done a body lift.  That must be one really warn out transfer case if it pops out often, and it's all stock otherwise.
1993 4-door Sidekick
4.24:1 t-case
  • 24
  • The Infamous
    • MySpace
« Reply #9 on: July 18, 2006, 03:09:20 AM »
yeah its all stock, its been in a accident and has a salvaged title. Other then that I dont know anything about this tracker. The ONLY reason I keep this tracker is because of the 4 wheel drive and without it, ill problly get rid of it.
Offline Digger
  • 1991
« Reply #10 on: July 18, 2006, 07:25:55 AM »
It's quite possible that the transmission mounting cross member might have been bent upwards, which would push the entire transfer case/transmission assembly up, causing the t-case lever to hit the transmission tunnel/floor opening and get pushed out of gear when it flexes... Easiest fix would be to remove the console, then remove the base of the boot around the tcase lever, slide it slightly forward and drill new holes and screw the base back down again. You might possibly need to trim a little of the front edge of the hole that the lever comes up through if the lever hits it when all the way forward...
« Reply #11 on: July 18, 2006, 04:34:58 PM »
Wow ACK, how do you really feel? LOL!
