In order of importance...
  • 11 Replies
  • 3058 Views
« on: May 23, 2006, 05:21:53 PM »
List armour in order of importance:
Pumpkin Caps
Taranny / Transfer case
Gas Can
Rail (nerf bars) for under door
Anything else?
~J~
Offline takai
  • 907
Re: In order of importance...
« Reply #1 on: May 23, 2006, 06:02:01 PM »
Bumpers (Front and Rear)
Our stock ones just aren't up to the task.  ;D
'Cause, I am to misbehave.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: May 23, 2006, 07:15:45 PM »
Pumpkin Caps
Gas Can
Anything else?
~J~
1. Rocker panel protection
2. Bumpers with good recovery points/strap attachment points
3. Skid plate under the front
Then worry about the tranny/t-case. I wouldn't even bother with a gas can unless you plan on wheeling alone for days on end away from civilization...
« Reply #3 on: May 23, 2006, 08:52:07 PM »
I can make the pumpkin caps, and rocker protection on my own no problem. Skid plate... I can probably do that. Just need to take some measurements... but the bumper...
I don't know if I'm up to the challenge of making my own bumpers or not. Want to make ones with receiver hitches so I can put winch on whatever side I need it on... and take off when home.  Looks like pre-fabricated bumpers are $$$$ especially with shipping *shudder*... so I'll probably be forced to at least try and make my own :)
~J~
Offline Digger
  • 1991
« Reply #4 on: May 23, 2006, 08:55:27 PM »
If you can whip up rocker protection, you should be able to whip up some bumpers... you can even buy the receiver sleeves at a Tractor Supply store ready to weld on to your bumpers...
Offline JayN
  • 220
« Reply #5 on: May 23, 2006, 09:39:17 PM »
cage
sliders
bumpers
skidplate
exo
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline magiccat
  • 98
  • 94 Sidekick 2.5 spacer lift 30x9.5 mt's
« Reply #6 on: May 23, 2006, 11:01:45 PM »
i'm in your same prediciment; the zuk needs protection also. I would agree with jayN.
cage
sliders
front skid
belly armor
bumpers
exo cage
then you'll be a zuk tank!
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #7 on: May 24, 2006, 04:30:32 AM »
In order of importance for protecting your sheet metal? or your expensive bits?
If sheet metal is your concern.
Rocker Skids  #1 most damaged sheet metal.
If mechanical protection is your aim.
Front Skid (aftermarket 4x4.. Sean Devinney.. the best I have yet seen for sale, yes I have one)
Transfer Skid  (calmini's is OK)
Trans Skid
Rear punkin protection... maybe truss like Calmini, but I hate the loss of clearance (No, I don't have one)
I have been wheeling this little guy for months with stock bumpers.. don't really see any need for aftermarket, except for recovery points..  I mean, I haven't hit anything with them.. but if you tend to hit trees a lot, then yeah, I guess you need heavy, expensive aftermarket or manufactured bumpers.. yeah they look great, and they are on my list... but never have been top of list, and I haven't needed anything more than stock so far... (fingers crossed) I think I will just get the Trail Tough bumpers..  about $300 each.. much cheaper than the competition, and they look better too.. (MUCH better than that abomination ARB sells.. that thing is UGLY)
Cage is near the top of the list too.
Offline the_maplebar
  • 466
« Reply #8 on: May 24, 2006, 10:00:37 AM »
You guys remember this is for a Sammy not a TrackKick right?
Offline JayN
  • 220
« Reply #9 on: May 24, 2006, 11:14:22 AM »
where does it say what protection for a sammi?
whats the difference anyway, still need all the same armour.
1970 gmc truck
1950 dodge truck
1974 corolla
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #10 on: May 24, 2006, 01:04:51 PM »
No.... I just assume EVERYONE has what I have!!!
SORRY~!!!
  • 466
« Reply #11 on: May 24, 2006, 01:43:14 PM »
The sig says he has an 88 Sammy.
Yes they both need protection.  I'm not really familiar with Sammy's but I would expect having solid axles, pumpkin protection would be more important than a front skid.  Also Sammy's seem to be higher with better breakover angles so rockrails are probably not as important as they are on TrackKicks.
I would say you are on the right track with:
Pumpkin
Tranny/TCase (maybe full belly pan)
Then I would watch your gas tank and rock rails to see how they do with your wheeling.  Definately get some rock sliders if you want to do this
