Powerloss 1500rpm
  • 17 Replies
  • 4511 Views
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
Powerloss 1500rpm
« on: February 08, 2005, 06:34:30 AM »
Ever since I got my tracker, theres been a slight loss of power when I get to 1500rpm. This is most apparent on cooler days but I drive a standard so it's pretty picky on the clutch action. Any suggestions as to what would cause it? It's only in the 1500-1600 rpm range, and after 1st gear its less apparent in 2nd, and no one drives in 3rd in that range without stalling so.. anywho any ideas or possible answers would help. thanks in advance. ???
« Last Edit: February 08, 2005, 06:35:27 AM by cbtracker »
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Offline TomKat
  • 211
Re: Powerloss 1500rpm
« Reply #1 on: February 08, 2005, 06:35:50 AM »
I had that issue a while back, turned out to be an O2.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: February 08, 2005, 06:42:04 AM »
Try to avoid that RPM range?  ???
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline adamd
  • 369
  • sofa king we todd it
« Reply #3 on: February 08, 2005, 06:44:32 AM »
Do they make 18 speed tranny's for sidekicks?
'98 kick
3" B/l
30" Mud Kings
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: February 08, 2005, 06:54:01 AM »
Well, Nate & Heather have a 20 speed!
Bob
Offline adamd
  • 369
« Reply #5 on: February 08, 2005, 06:58:36 AM »
Problem solved. Next issue.
~Zukiworld Mechanic Staff
'98 kick
3" B/l
30" Mud Kings
Offline 3wheelerdude
  • 70
« Reply #6 on: February 08, 2005, 07:58:47 AM »
I have the same problem but its around 2500 to 2800, mostly in fourth gear. Its almost as if its got less torque at that right exact spot.........wierd.
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: February 08, 2005, 08:07:16 AM »
Hahaha..
20 forward gears and 4 reverse gears. You're close.
But it takes 3 sticks to do it.
I guess technically there's 5 more if you consider 4 hi another set of gears..
;D
« Last Edit: February 08, 2005, 08:10:35 AM by hcgalvin »
Heather Galvin
« Reply #8 on: February 08, 2005, 08:08:29 AM »
Could be spark plugs !
Offline mahimahimo
  • 377
« Reply #9 on: February 08, 2005, 08:20:20 AM »
20 spd?          im a little confused ??? ??? ??? ???
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: February 08, 2005, 08:34:28 AM »
I'll explain:
2HI
1,2,3,4,5
4HI
1,2,3,4,5
Regular 4LOW
1,2,3,4,5
LOW 4.24
1,2,3,4,5
LOW+LOW 4.24
1,2,3,4,5
Reverse
2HI 1
4HI 1
4LOW 1
LOW 4.24 1
LOW+LOW 4.24 1
OK, so 25 forward gears, and 5 reverse gears.
« Last Edit: February 08, 2005, 08:35:23 AM by hcgalvin »
Heather Galvin
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #11 on: February 08, 2005, 10:38:21 AM »
A failing crank pulley Keyway will show as a loss of power below 3k rpms.  More noticable when cold.  A sure way to tell would be to check the truck with a timing light.  If the timing mark is jumping around , not sitting steady at a consistant place or looks to be out of time (I forget the correct # of Degrees).   Then I would look for a bad pulley / keyway.
Just my most recent issue.  Hope yous is simpler.
« Last Edit: February 08, 2005, 10:39:10 AM by whitfield »
  • 70
« Reply #12 on: February 08, 2005, 11:52:12 AM »
what exactly is a bad pulley/keyway? any other way than with the timing light to check it, unfortunately I dont own a light.
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline 90Stomper
  • 427
« Reply #13 on: February 08, 2005, 12:33:11 PM »
thought i was the only one to have this prob!
it is the pully on the top front of the motor that is on the end of the cam shaft, under that black plastic cover in the front.  you could undo a few bolts and pull it back a bit and see if you can see the center keyway is messed up or not.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
« Reply #14 on: February 08, 2005, 12:57:38 PM »
prob. talking bout the lower pulley.
