VIN #
  • 27 Replies
  • 10855 Views
Offline Autobot
  • 189
  • Danger Can Happen!
VIN #
« on: February 07, 2005, 07:56:22 AM »
  Is there a way to decode the VIN # on a track/kick to see the exact info on it? By that I mean like, where it was made, options,parts differences between models etc?
Got Tracker?
2000 2dr. convertible, stock.
Re: VIN #
« Reply #1 on: February 07, 2005, 08:40:11 AM »
yep. down load the fsm. from http://www.ackerdackerly.com/samuraiindex.html it's in three parts, for a sammie but should give you what your looking for.
Offline hcgalvin
  • 1695
    • Granite Path
Re: VIN #
« Reply #2 on: February 07, 2005, 09:08:56 AM »
There are some free sites that will let you put in a VIN code and see what it says.
I'm not remembering what they are right now, but Google VIN decoding and you should get a few.
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: VIN #
« Reply #3 on: February 07, 2005, 09:12:34 AM »
Sammi, or Track/Kick?
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline hcgalvin
  • 1695
    • Granite Path
Re: VIN #
« Reply #4 on: February 07, 2005, 09:15:32 AM »
Bob, get some glasses.
;D
Heather Galvin
Re: VIN #
« Reply #5 on: February 07, 2005, 09:16:30 AM »
What's a matter Bobzooki ? have too much coffee today?  Read man read.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: VIN #
« Reply #6 on: February 07, 2005, 09:31:16 AM »
Oh, crap.  My brain musta slipped a tooth on the cam between the beginning and end of this thread...
Well, the ackerdackerly fsm won't cover the Track/Kick - will it?
Anyway, if it starts with a J it's built in Japan, and if it starts with a 2S3 it's a CAMI Kick.
Bob
Re: VIN #
« Reply #7 on: February 07, 2005, 09:38:34 AM »
The vin #'s should all be the same, be it a chebby or zuk ect. I could be wrong though.
Offline Autobot
  • 189
Re: VIN #
« Reply #8 on: February 07, 2005, 09:47:16 AM »
... J it's built in Japan, and if it starts with a 2S3 it's a CAMI Kick.
a CAMI kick?   ???
Got Tracker?
Offline hcgalvin
  • 1695
    • Granite Path
Re: VIN #
« Reply #9 on: February 07, 2005, 09:51:49 AM »
a CAMI kick?   ???
Built in Canada at the CAMI plant.
Heather Galvin
Offline Autobot
  • 189
Re: VIN #
« Reply #10 on: February 07, 2005, 10:14:15 AM »
 Well I found one, well 2 actually.
http://www.vehicleidentificationnumber.com/carfax.html
http://www.analogx.com/contents/vinview.htm
 Turns out I've got a Canadian Tracker. Mine actually starts with 2CN though and not 2S3. I guess 2S3 is for Sidekicks. I was searching for a specific Geo/Suzuki decoder like they have for chevys and whatnot to tell you the exact info, but I can't seem to find one.  :P
« Last Edit: February 07, 2005, 10:17:43 AM by Autobot »
Got Tracker?
Offline SnoFalls
  • 1358
Re: VIN #
« Reply #11 on: February 07, 2005, 11:05:38 AM »
My FSM has some decode info for the VIN ... I can scan/summarize l8r ...
RPO is the meat ... (check the glove box sticker)
http://www.nastyz28.com/rpomenu.html
(note this list is pretty good but none are fully complete)
Rob
Re: VIN #
« Reply #12 on: February 07, 2005, 12:26:47 PM »
     Here's what my FSM for a 95 Tracker describes the codes, in order left to right.  In paranthesis is the example it gives.
1.  Nation of Origin (2 : Canada)
2. Manufacturer (C : CAMI/GM of Canda/ Suzuki J.V.)
3. Make and Type (N : multipurpose pass vehicle)
4. GWR in pounds (B : 3001-4000, hydraulic brake system)
5. Line and Chassis Type (E : compact cab, 4x2.  J : compact cab 4x4)
6. Truck series (1 : 1/2 ton)
7.  Truck Body Type (8 : Jimmy/Tracker)
8.  Engine type & make (U : 1.6 L4 TBI, Suzuki)
9.  check digit
10.  Model year (S : 95)
11.  Assembly plant code (6 : Ingersoll, Ont.)
12.  plant sequential number (900001)
I have a '92 Kick that doesn't seem to correspond to these so I believe the Suzukis use different codes.   ???Hope this makes some sense!
Offline zukisuzi
  • 102
Re: VIN #
« Reply #13 on: February 07, 2005, 12:39:13 PM »
Here's a scan from my '87 Samurai FSM:
"I was so poor growin' up, if I wasn't a boy I'd've had nothin' to play with..."
--Rodney Dangerfield
Offline blacknight
  • 987
    • Gonzookin
Re: VIN #
« Reply #14 on: February 07, 2005, 12:44:40 PM »
Found this work pretty good
George
