16-8 Valve???
  • 1690 Views
Offline blakester1123
  • 95
  • 88 sammy 6in on 32s and rising
16-8 Valve???
« on: June 23, 2006, 11:39:19 AM »
will a 16 valve tracker engine work with the calmini adapter plate for the samurai?
Offline takai
  • 907
Re: 16-8 Valve???
« Reply #1 on: June 23, 2006, 01:21:24 PM »
I am running a 16v in my Sammi. The conversion was done by TT, but I don't see why they wouldn't have an adapter. It is a fairly common swap.
'Cause, I am to misbehave.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: 16-8 Valve???
« Reply #2 on: June 23, 2006, 03:43:29 PM »
I assume you mean the engine adapter plate...
Yes!
The block on an 8-valve and 16-valve is (nominally) the same.  Different years may have more or fewer sensor holes but where it bolts to the transmission is identical.
Ack
  • 95
Re: 16-8 Valve???
« Reply #3 on: June 24, 2006, 03:43:40 PM »
thanks alot ack,
