4dr PS in a 2 dr?
4dr PS in a 2 dr?
TysonS
383
www.funinbc.com
4dr PS in a 2 dr?
July 27, 2006, 11:55:15 PM »
can i just take the power steering out of a 4dr kick with all the brakets and just bolt it in on my 2dr?
thanks
2 Dr. 91' 8v Sidekick| 3" Body Lift | 4" Gas Tank Lift | 3.5" Suspension Lift | Snorkel | Custom Bumpers | Sliders | 31" LTB's | Detroit | 4.24 Tcase | TT front locker soon
biker
730
7
It's a sickness I tell ya
Re: 4dr PS in a 2 dr?
July 28, 2006, 06:51:53 AM »
I took my PS off a 4 door with a 16v, it bolts on but I found that the pulley didn't align properly with the crank pulley so I had to tweak the bracket a little.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
TysonS
383
www.funinbc.com
July 28, 2006, 08:06:02 PM »
this is a 8V i belive so, i should be good to go
TysonS
383
www.funinbc.com
Reply #3 on:
July 29, 2006, 06:16:44 PM »
well, i bought it, im going to paint it and try it out in the next few days
wildgoody
8134
67
Reply #4 on:
July 29, 2006, 11:55:37 PM »
Power steering requires it's own pulley,
so grab that too, makes the install easier
TysonS
383
www.funinbc.com
Reply #5 on:
July 30, 2006, 07:33:49 AM »
i got the pully aswell, going to be putting it in tomorrow i think
da_tub
307
oops...can we still back up>?
Reply #6 on:
July 30, 2006, 09:01:55 PM »
should go together nicely then good luck..... i know i iove my power steerng when i'm wheelin..(
91 four door ,and some stuff
TysonS
383
www.funinbc.com
Reply #7 on:
July 31, 2006, 09:35:18 PM »
well, looks like im going to have to take the rad out to get the box into place. anyone with the 4dr box and the 2dr shaft have a problem with the shaft being too long and the splined shaft on the box hitting the little u joint on the steering shaft
i donno if that made sence
wildgoody
8134
67
Reply #8 on:
July 31, 2006, 10:37:54 PM »
Are the shafts different between the
two boxes? did you get the 4 door shaft
to match the box?
TysonS
383
www.funinbc.com
Reply #9 on:
July 31, 2006, 11:09:29 PM »
no i didn't get the 4 dr shaft, the splines are the same but the 4dr box is longer then my 2dr standard so that extra depth might made the splines off the shaft on the box go in to far and get into the little steering u joint? it just looks this way
TysonS
383
www.funinbc.com
Reply #10 on:
August 01, 2006, 06:38:36 PM »
ok, i got it in and took it for a rip and it is barley working? is there any special way to bleed the line or some trick to make it work better?
fordi64x4
9
I Love ZUKIWORLD!
Reply #11 on:
August 01, 2006, 06:39:46 PM »
you got it all out tyson? i threw the belt over in the ford section if you still need it haha
TysonS
383
www.funinbc.com
Reply #12 on:
August 02, 2006, 10:11:17 PM »
ok, it wasn't working very good and i made the belt tighter and it is working better. can i just make the belt as tight as i can?
da_tub
307
Reply #13 on:
August 02, 2006, 11:39:50 PM »
not too tight.... but tight..
TysonS
383
www.funinbc.com
Reply #14 on:
August 03, 2006, 10:21:27 AM »
When I rev the engine up I get alot better steering so I think it is the belt being to loose. Going to get the propor bolts from the suzuki dealer today and I will tighten it up and see how its doing then. . . will maybe take some pics if someone likes
