Ticking from somewhere?
  • 1788 Views
Offline fullsink18
  • 250
  • Wheel Me!
« on: August 20, 2006, 10:26:14 AM »
My zuk can good all weakend, but the last day I got on a mound and seasawed the rig on the frame.  After that there was a tick sound that started only when on the throttle.  If I down shift no ticking.  If I pump the gas pedal it ticks or if i am going down the road it ticks.
I think I may have messed up my exhuast, it may be leaking.  I dont think it is the valves because it only happens when on the throttle.  Sounds kind of like a lawn mower.  Any suggestions.
Oh brand new calmini exhuast.  150,000 miles.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Re: Ticking from somewhere?
« Reply #1 on: August 20, 2006, 10:48:29 AM »
Exhaust has a spring and bold Cat clamp,
you probably seperated it and you have
a leak, just fix that, should be good
Offline fullsink18
  • 250
  • Wheel Me!
« Reply #2 on: August 21, 2006, 06:50:08 AM »
I did not use the spring bolt clamp on the new calmini exhuast.  But where the header connects to the cat the gasket calmini gave me broke so we put a donut in there and it is leaking around there.  Not to bad but it does sound like a lawm mower coming down the road.
I suppose if I drop the exhuast down from the header that would narrow the problem down.
94 2dr kick 8v
Offline holeypockets
  • 68
  • i think DENTS are pretty
« Reply #3 on: August 21, 2006, 04:45:38 PM »
wait a little bit and look for black carbon biuld up.  that will tell you if and where the leak is.
i just like dents, i don't know why.
