1.6L HP increases
  • 24 Replies
  • 12279 Views
PSYKOCHI
1.6L HP increases
« on: September 22, 2006, 05:44:34 PM »
Guys I have a 95 Geo Tracker "Psyko Chiwaawaa" that I drag race.  Although the engine is pretty much stock w/ a header, I want a HP increase without killing my budget.  I know the rods can't take a whole lot of stress without rebuilding the bottom end.  I do want to stay with the Zook 1.6L.  I do not want to swap engines.  The 1.6 is lightweight -- I just want a little more HP.  I do have a '96 Tracker 1.6L 16V engine but I don't want to run the 16V head.  I want to use my 8V head on this engine.  So far the truck weight is 1840lbs w/o the driver.
« Last Edit: September 22, 2006, 05:55:01 PM by PSYKOCHI »
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: 1.6L HP increases
« Reply #1 on: September 22, 2006, 05:50:56 PM »
Cam, exhaust, intake, the basics... eliminate the Cat if you can.. that type of stuff.. how much of that have ya done??
how about a ''lil" shot of nitrous? :o
PSYKOCHI
« Reply #2 on: September 22, 2006, 06:00:53 PM »
Wide open header with a 14in extension.  Cam?  I need one don't know where to find one.  More fuel -- how can I increase the amount of fuel to a TBI?  No headwork as of yet.  I would like to stay away from NOS.
I like normally aspirated.   I would like to use a good 2bbl carb.
« Last Edit: October 02, 2006, 06:15:59 PM by PSYKOCHI »
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #3 on: September 22, 2006, 07:32:18 PM »
you def. want to keep the 16v head dont, i repeat dont use the 8v, try porting the head, depending on your budget theres a guy who built his 1.6l 16v and turboed it. hes now selling it for $2200 for everything including fuel management
95XL7
« Reply #4 on: September 22, 2006, 07:34:41 PM »
One word.....LS1
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #5 on: September 22, 2006, 09:19:02 PM »
http://www.teamswift.net/viewforum.php?f=7
http://www.rocky-road.com/kickpulley.html
http://www.hawksuzukiparts.com/
Here at HAWK STRICTLY SUZUKI we are big in
cams. We have a wide variety for you to
choose from or we can special make any cam
for any application. Call us! Here are some of
the more popular models:
New Stock OEM $99 w/o core
Phase 1 torquer $100 w/$25 core
PSYKOCHI
« Reply #6 on: September 24, 2006, 05:07:28 PM »
I have read someplace (online) -- one guy tested the 16V vs. 8V head and he said the 8V flowed better.  I can't remember were I saw it, I will look for it again.  I have always heard a 16V will outflow an 8V but for some reason this was a different case.  I will try and find it.  I have both heads -- I could take them to a friend of mine and have him flow them both.  Yes I do understand 16V motor has more HP -- It also has MPI.  I am still open for suggestions -- I haven' got rid of my 16V head yet.
PSYKOCHI
« Reply #7 on: September 24, 2006, 05:26:54 PM »
One word.....LS1
You have a very good idea!!
  • 238
« Reply #8 on: September 24, 2006, 05:43:24 PM »
port the 16v head, you wont be disappointed, trust me. alot of people underestimate the 16v motor. the guy i told about that built and turboed his 16v said he raced his friends stock wrx and he said he beat it by 3 cars lengths
PSYKOCHI
« Reply #9 on: September 24, 2006, 05:51:21 PM »
A stock WRX runs in the 13s off the show room floor -- I am impressed....... :o    1/4mi?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #10 on: September 24, 2006, 06:10:39 PM »
The SOHC 16v head of the 1.6 outflows the DOHC 16v head of the Suzuki Swift GT. I'd be highly surprised if the 8v head outflowed it. Keep the 16v and get some cam work done on it and you can use the 1.3 flywheel as it is lighter than the 1.6. Mine responded well to a cam regrind and an adjustable cam gear. I had also done the complete exhaust  on mine. The next step was going to an interceptor for the fuel and ignition as these have given reasonable gains. A little pocket porting won't go astray either. You may want to hunt around for different diff ratios. Maybe a 5.38 or a 5.62 to get of the line quicker. You'll need to do some calculations to find your best option.
PSYKOCHI
« Reply #11 on: September 24, 2006, 06:20:00 PM »
Thanks for the info -- I am not planning on getting rid of the 16V head -- I just want more info before I drop any more money into my little hot rod.  With the very limited availability of speed parts for the Zook motors it makes gaining HP a little difficult and a deep gouge into the light budget.
95XL7
« Reply #12 on: September 24, 2006, 06:58:00 PM »
Or maybe some mods like this one.......
  • 238
« Reply #13 on: September 24, 2006, 07:02:48 PM »
more info please... :o :o ;D
Offline locjaw
  • 2045
  • 22
« Reply #14 on: September 24, 2006, 08:05:25 PM »
it has stacks, what more info do you need ;D
jason
