Good Year Wranglers
  • 2820 Views
Offline stosh22
  • 16
Good Year Wranglers
« on: September 26, 2006, 10:30:05 AM »
I got a decent deal on some Good Year Wrangler Silent Armors - 31x10.50s that I was going to put on a set of 15x7 w/2.5" backspace.
Anyone ever try these out?  I live in Sask, Canada and we can be driving on ice for a couple months so I wasn't sure how well a more agressive tire would pan out since this is my year round DD.
I wasn't sure how an mt tire would handle in the ice and snow but I still hoped these SA's would give some bite off road too....
I ordered up a 2.5"RRO lift and am putting on a home made 3"BL
1992 Suzuki Sidekick 2dr 1.6l 8v, 3" Body Lift, 2.5" RRO Lift, 31 x 10.50 Pro Comp Mud Terrains mounted on 15 x 7 3" bs rims from RRO.  Thorley Header, K & N Filter.  Lifted Gas tank.
Re: Good Year Wranglers
« Reply #1 on: September 26, 2006, 06:34:51 PM »
THese?
Probley get decent MPG
Very mild A/T
I Use something like that on my D.D. (31"s)
get 27 1/2 mpg on a 97 Kick
Offline stosh22
  • 16
« Reply #2 on: September 26, 2006, 07:59:05 PM »
Those are the tires, supposed to be great in the winter
I guess my other option is to try find the biggest set of winter tires that will fit on my stock sidekick aluminum rims.
Any opinion on 15x7 or 15x8 with the 31x10.50 or the best backset?
Offline 4njeep
  • 113
  • I Love ZUKIWORLD!!!!
« Reply #3 on: September 26, 2006, 08:10:24 PM »
imho those are going to be great tires for a year round DD, and if you run a 2.5 " off set, that might be a little to much for daily driving, if you run about a 3.75" off set, they should just stick out the fenders a little, that way you wont get buged by the cops.
i run a 15x7 with a 3.75 off set, and 30" tires, and they are flush with the edge of the fender, maybe stick out about 3/8"  i have lots of room between the tire and the frame at full lock, about .5"
when i had 235/75/15 tires on the exact same rims you have, they rubbed at full lock.
another good tire for winter is the BFG A/T TA's and something simular is the general grabber at2, but its alot cheaper.
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
Offline r3cc0s
  • 321
« Reply #4 on: September 26, 2006, 09:46:53 PM »
Those silent armours are supposed to be the really good road tires
As for actual mudding... or even rock crawling, I just don't think there is enough rubber nor lugs to be a real contender
If I had a work truck, those would go on there for sure, for simple construction sites, ice and snow those are great tires... they are basically the new version of the goodyear AT/S with the durawall silica technology
Anyways... I still like goodyear so I bought MT/R's
Offline stosh22
  • 16
« Reply #5 on: September 27, 2006, 07:28:04 AM »
Any idea what the width of the stock rims is
« Reply #6 on: September 27, 2006, 10:05:39 AM »
Stock rims are usually 5.5".
