still high !!!!
  • 1624 Views
Offline bus_driver
  • 479
  • the voices tell me different things
still high !!!!
« on: October 16, 2006, 11:39:45 AM »
my RPM that is ..... I changed my 02 sensor and now i have done the cold start pellet block and tightened up my exhaust for no leak ...now the truck is running great and sounds really good but I still am running at 1200-1300 rpm it does not go up and down or anything but it just sits there ......is there an idle adjust on these thing or should I look at something else...the throttle cable is not tight and the air filter is clean...I sprayed the vacuum lines with wd40 looking for leaks and no change at all. I cleaned up the plugs but did not do a great job of it. is there a TPS on these g16a motors? and if so where is it?
any suggestions would be helpful oh yeah I even checked the tire pressures????hahahaha
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Re: still high !!!!
« Reply #1 on: October 16, 2006, 12:01:38 PM »
There is a TPS and an idle adjust too. If you haven't already done it download an FSM from
http://www.suzukiinfo.com
You probably need an analogue multimeter, IIRC you need to set the idle speed so that the Idle Speed Controller is at 50% duty cycle.
Offline bus_driver
  • 479
Re: still high !!!!
« Reply #2 on: October 17, 2006, 12:07:10 AM »
wow that was really technical. IIRC? what is that.
so there is no idle screw huh?
92 2dr soft top
235/75/15
2 inch lift
custom mud
