RPMs
  • 30 Replies
  • 7887 Views
Offline 3wheelerdude
  • 70
RPMs
« on: January 13, 2005, 01:45:34 PM »
What should the RPMs indicate when going 100km/h (or 60 m/h) in fifth gear, on a 1.6 sidekick. (no mods)
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline bandit86
  • 1641
  • elv8rguy
Re: RPMs
« Reply #1 on: January 13, 2005, 01:57:08 PM »
check your tach, its beside the speedo in the gauges, it'll tell you
Re: RPMs
« Reply #2 on: January 13, 2005, 02:00:26 PM »
about 3500 rpm's.
  • 70
Re: RPMs
« Reply #3 on: January 13, 2005, 02:00:28 PM »
I know, but I find mine is pretty high and I just got the truck so i would like to make sure its normal. Mine reads about 3500. How ddoes that sound??
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
  • 70
Re: RPMs
« Reply #4 on: January 13, 2005, 02:01:56 PM »
about 3500 rpm's.
Thank you!!!!!!! I shall forever thank you for reassuring me. Someone on another forum told me it should be 2600........thats why i was kinda freaking out.
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline W7ACT
  • 30
Re: RPMs
« Reply #5 on: January 13, 2005, 02:09:01 PM »
There's to many variables to give you a correct answer to your question to change anyone of the variables  can change the answer to the question. What gears are you running in the tranny, in the rear end, what size tires are you running.   You change each,  any one or all of these factors and you can get a differant answer.
A good case in point an number of years ago I drove for a company in Eastern Washington we had two trucks they were Identical in very respect the only difference was the Serial Number and that was by one number they came off the assembly line one behind the other and were delivered to the same company one would out run the other every time it was given.
  • 70
Re: RPMs
« Reply #6 on: January 13, 2005, 02:52:37 PM »
alright, sorry if my question was a bit LARGE, but it still feels good to know that im not the only one who runs high RPMs at 100km/h.
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Re: RPMs
« Reply #7 on: January 13, 2005, 03:10:41 PM »
With 5.83 gears and 33" tires
I'm pulling about 4300-4400
RPM at 70 MPH (about 110 Kmh)
« Last Edit: January 13, 2005, 03:11:57 PM by wildgoody »
Offline 92Sidekick4x4
  • 1456
Re: RPMs
« Reply #8 on: January 13, 2005, 03:35:34 PM »
when i do my drive on the highway everyweekend, i do about 100 kmh |removethispart|@ around 3400 rpm
Offline 1bigtracker
  • 3409
Re: RPMs
« Reply #9 on: January 13, 2005, 10:29:17 PM »
don't be afraid to take a 1.6 to to 6000RPM+.   very strong engine.  i have over heated mine many times and it still won't blow.
stu
  • 1456
Re: RPMs
« Reply #10 on: January 14, 2005, 02:24:03 AM »
stu
6 grand? thats pretty high, anyone else do this?
Offline Natebert
  • 1098
Re: RPMs
« Reply #11 on: January 14, 2005, 02:28:05 AM »
We hit 5500 every time we take it up to 75mph.
We've run this way for hours at a time.
I've seen it hit 6500 no problems.
~Nate
« Last Edit: January 14, 2005, 02:28:40 AM by natebert »
  • 1456
Re: RPMs
« Reply #12 on: January 14, 2005, 08:10:46 AM »
hm, thats good to know, thanks! :)
Re: RPMs
« Reply #13 on: January 14, 2005, 09:14:20 AM »
You might be talking about two diffrent engines also, the 16 valve and the eight valve are a little bit diffrent on the top ends and the bottom ends. I think my 16 valve shuts down at 6500 by the ecm.
Re: RPMs
« Reply #14 on: January 14, 2005, 03:58:53 PM »
I hit 6000 in first and second, but by
the time I'm to 6000 in third I'm going
over 100 MPH
