sammi t-case shifting trouble???
  • 21 Replies
  • 4743 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: January 09, 2005, 10:33:07 AM »
OK, gettin ready to put this sammi case I have into my tracker. I have it on the floor, and try to run through the shift pattern. I have 2wd hi, and 4wd hi, but I can't get into low??  ???
The shifter only moves back and forth, not to either side AT ALL. Do I have a problem?
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: sammi t-case shifting trouble???
« Reply #1 on: January 09, 2005, 11:44:42 AM »
Shift rods weren't lined up right or the shifter sheet is bad.
Offline Chief
  • 678
« Reply #2 on: January 09, 2005, 08:59:46 PM »
What's the fix?
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #3 on: January 10, 2005, 01:37:16 AM »
What's the fix?
Pull the shifter, align the shifter forks and make a square box. Ensure that the rubber bushing under the shifter ball is in good shape. If not order a new shifter sheet (bushing) Put in the bushing, Put the shifter back in and it should work like a champ
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #4 on: January 10, 2005, 03:24:58 AM »
if ur sammi has more than 50,000 miles on it replace the spring, shifter pin, and the shifter bushing that should cure ur problem or just order the kit form hawk. http://www.hawksuzukiparts.com/
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
« Reply #5 on: January 10, 2005, 08:18:51 AM »
I think the kit that you are talking about is for the trans! not the tranfer case.
Offline Chief
  • 678
« Reply #6 on: January 10, 2005, 10:29:39 AM »
Any pics? Also, what do you mean make a box? Make a box with the shifter forks?? Never had the top end of a t-case apart!
Offline Chief
  • 678
« Reply #7 on: January 10, 2005, 10:34:06 AM »
OK, youguys are confusing me!!
I'm having trouble with my TRANSFER case!  ;)
Offline TN_Tracker
  • 1113
« Reply #8 on: January 10, 2005, 10:46:25 AM »
Pull the TC Shifter, there are two shift rods that should look like this [size=10][][/size] if aligned properly in neutral. Check the rubber bushing (sheet) to see if it's worn.
« Last Edit: January 10, 2005, 10:48:37 AM by TN_Tracker »
Offline Chief
  • 678
« Reply #9 on: January 10, 2005, 01:44:29 PM »
and that rubber bushing is right under the shifter, correct? Thanks for the help!
« Reply #10 on: January 11, 2005, 03:40:05 AM »
If your lucky you can pull the shifter out and use a  large screw driver to align the shift pins without taking apart the case.
I know someone sold a tool you could use to pop the spring plate off without having to drop the transfer case, not sure where to get it though.  You could make one easily enough though.
Offline Chief
  • 678
« Reply #11 on: January 11, 2005, 02:27:10 PM »
shift rods = shift pins???
Is there some bible on sammi cases so I can do some research???? ???
« Reply #12 on: January 11, 2005, 05:02:19 PM »
So how far have you gotten? do you have the shifter out yet? is your shift sheet good? how are your [] looking when you look down the shifter hole? do you know the shift pattern?
Offline Chief
  • 678
« Reply #13 on: January 11, 2005, 08:53:27 PM »
No where!! Just got the trackick back together yesterday. Grounded the starter, put the manifold and exhaust back on, rear d-shaft, modified 4x4 tranny x-member.
Today's the intake, adjust clutch linkage, get shocks mounted in the rear, redo the coil captire for the rear springs, and then I'll do the shifter. I hope it's nothing serious!!!! :-/
« Reply #14 on: January 12, 2005, 03:43:52 AM »
Can you take some pictures of your Transfer Case where your shifter goes in?
