Spring rates
  • 19 Replies
  • 5535 Views
Offline Chief
  • 678
  • Whaddya lookin at??
Spring rates
« on: January 12, 2005, 01:11:06 PM »
Whats the stock spring rate for the rear end of a 2 dr trackick?? The XJ coils I had where just too stiff. Was trying to find a coil that I can mount in the stock location, and capturing both ends, but still get full travel out of the rear end.
I was thinking of maybe QA 1 coils in about a 14" uncompressed length. Whaddya think?
Re: Spring rates
« Reply #1 on: January 12, 2005, 02:02:00 PM »
200-225 should be soft enough
I bet the stockers are closer to
250-275 tho.
Let me see if I can look it up
OK, factory specs
rate is 156.5 pounds per inch
Hope this helps
« Last Edit: January 12, 2005, 02:08:16 PM by wildgoody »
Offline Chief
  • 678
Re: Spring rates
« Reply #2 on: January 12, 2005, 08:49:05 PM »
250-275 tho.
OK, factory specs
Hope this helps
Gives me a place to start. Thanks!
Offline cj
  • 1276
  • I drive a really big ATV
Re: Spring rates
« Reply #3 on: January 12, 2005, 09:17:41 PM »
Old Man Emu for a 2dr has a  spring rate of 140. Their 4dr is 180 and 4dr heavy is 200. This may give you some assistance. I found the 2dr in my swb reasonable but not super flexy and the 4dr heavy in my lwb quite stiff. The Calmini 3" suspension in my lwb is quite soft by comparison.
Offline blacknight
  • 987
    • Gonzookin
Re: Spring rates
« Reply #4 on: January 12, 2005, 11:24:54 PM »
Where are you guys getting this info from ??? I would love to get access to info like this for my XL-7
George
Re: Spring rates
« Reply #5 on: January 13, 2005, 04:23:07 AM »
I have a USDOT factory spec sheet
in PDF format that I saw someplace
(could of been on ZW) and saved for
future reference, like now  ;D
Offline mesjr2004
  • 422
Re: Spring rates
« Reply #6 on: January 13, 2005, 11:27:48 AM »
wish i would have waited till tomorrow to order springs,i ordered 200lbs for front and have 175lbs for rear.i think 175lbs for front and 150lbs rear would have ben better.,guess ill call tomorrow and see if i can change it :-/
mudfkr
Re: Spring rates
« Reply #7 on: January 13, 2005, 01:29:55 PM »
I think it's still in the files section at http://autos.groups.yahoo.com/group/sidekicksandtrackers/
Re: Spring rates
« Reply #8 on: January 13, 2005, 02:55:15 PM »
Should be good, what are these going
onto ? an SAS Kick or a Sammy ?
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: Spring rates
« Reply #9 on: January 13, 2005, 05:51:24 PM »
Just a note *   Kick 4dr front spring is 500 ppi +
(512#  I think)
Offline Chief
  • 678
Re: Spring rates
« Reply #10 on: January 13, 2005, 08:50:01 PM »
Where did you get em from, got a website?
Also, anyone know the lengths of various lifted coils, uncompressed?
Offline Wildweasel
  • 106
  • Git er Done!
    • Wildweasel's world
Re: Spring rates
« Reply #11 on: January 13, 2005, 10:18:35 PM »
Go with the 175 and 200. if you have a bigger than stock spare and any add-ons you will need the weight.
These coil rates are for SAS use NOT IFS. the 175 will work on an IFS truck, but the 200 in front will be WAY too soft.
The stock 2 door is in the 400 Lb range.  (I think going off of memory.)
« Last Edit: January 13, 2005, 10:20:49 PM by Wildweasel »
Glenn
91 geo tracker, Toyota axles, twin tcases,35's too many mods to list.
Re: Spring rates
« Reply #12 on: January 14, 2005, 03:19:10 AM »
452.5 PSI/Inch if you really need it
Offline Chief
  • 678
Re: Spring rates
« Reply #13 on: January 14, 2005, 11:48:20 AM »
ok, I was thinking about going with a 175 lbs spring that is 3" longer then a stock, uncompressed spring.
I'm looking at QA1's right now. How does this sound?
Something like this.
« Last Edit: January 14, 2005, 11:53:47 AM by Chief »
Re: Spring rates
« Reply #14 on: January 14, 2005, 03:51:11 PM »
That's fine if you want to buy the
coilover shocks to go with them.
Nobody makes a spring that is the
same size as a Track/Kick (dia)
The springs you are looking at there
will not fit your trucklet, sorry
