New here
  • 2817 Views
Offline 2K-Otic
  • 16
New here
« on: January 18, 2007, 07:45:23 PM »
Hi all! I'm new to this forum. I came over from www.zuwharrie.com. I've been finding a ton of new ideas and information here.
Here's the specs on my rig:
   92 Tracker with 2" home made coil spacers, 3" home made body lift, and a 3" cold air intake purchased off e-bay. It's rolling on 31x10.5 Mud Kings mounted on 15x8 (2.5" B.S.) 8 spoke U.S. Wheels. It has the 1.6l 8v engine with a five speed. It's rusty and in need of some serious trimming and bobbing (a la the Rockstar style). ;D
Here's a couple pics.
92 Tracker
     2" Home made coil spring spacers
     3" Home made body lift
     3" Cold air intake
     31x10.5 Mud Kings on 15x8 spoke wheels
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: New here
« Reply #1 on: January 18, 2007, 07:56:17 PM »
welcome to our humble little world ;D
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Toy Box
  • 222
  • 00 Grand Vitara
Re: New here
« Reply #2 on: January 18, 2007, 08:15:18 PM »
Nice rig Welcome :)
You Play you Pay
Re: New here
« Reply #3 on: January 18, 2007, 10:03:08 PM »
welcome aboard 2K-Otic
The tires look like 33"s from the side. ;D
Looks good.
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: New here
« Reply #4 on: January 19, 2007, 03:27:22 PM »
Yeah, you are totally screwed now.... I just came by for a quick question about a year ago... and haven't been able to leave...
Got any sort of locker in the rear of that thing yet?
Lock it up, and run those tires at about 5psi and go piss off a bunch of Sammy owners... that's what I like to do... LOL
Welcome, and keep us posted with what you do TO it, and better yet pictures of what you do WITH it...
Offline 2K-Otic
  • 16
Re: New here
« Reply #5 on: January 19, 2007, 04:39:47 PM »
Yeah I think you're right. I haven't actually measured them yet, but they do seem a lot bigger than the 30x9.5's on my Jeep
 ;D
I know what you're talking about. The Tracker was supposed to be just a little diversion to get me through fall and winter until I could really get going on my Jeep project...but now I think this might be my full time project.
I dont have a locker yet, but it's coming soon. I got hi-centered yesterday and had opposite corners dangling in the air. Needless to say I was stuck...pulled out the trusty Hi-lift and got it off there. Ticked me off though...I'll be ordering a spool probably in the next week.
I'll try to get some action pics, and keep everyone up to date as it evolves.
92 Tracker
     3" Cold air intake
Offline sidekick101
  • 128
  • best site on the net
Re: New here
« Reply #6 on: January 19, 2007, 04:42:09 PM »
hey hey welcome to the site. gonna be hooked on it for a long time. lotys of good people and info. gonna bug you already tho hahah. how did make your coil spacers? is it hard or somthing someone with a bit of knoledge could do. and i was gonna do the same to my rig( same lift) how tall rea you so i have a comparison for hight. sorry for all the questions but liek to knwo as much as i can. and welcome welcome to our enthzuki  world
1993 sidekick JX, 2 dr, soft top, automatic,
Offline 2K-Otic
  • 16
Re: New here
« Reply #7 on: January 19, 2007, 08:40:57 PM »
Sidekick,
I'm about 6'3" tall to give you some idea of how much lift I actually ended up with.
I made my coil spacers from a 4" diameter solid rod of UHMW Polyethylene that I bought from www.mcmaster.com, part number 8701k59. It goes for about $22 per foot + $5 or $6 shipping. They are not hard to make at all if you have some basic shop equipment or access to it. The hardest part is cutting the rod to length and keeping it close to square. The material is very dense and can be a little difficult to cut...not impossible, just a PITA. I have a cheapo horizontal band saw that i used (still didn't come out perfect because of blade deflection, but it doesn't have to be perfect ;D). I'm sure there are other ways you could cut it...it would just take a little extra work & patience. After you cut them to length you must cut a hole through them to fit over the bumpstop. To cut the holes you use a centering head for a combo square to mark the center point. You then drill a pilot hole all the way through the spacer. Then use a 2.5" diameter hole saw to cut out the hole. Most hole saws wont cut deep enough to go all the way through in one pass so you will need to drill half way, flip the piece over and drill through from the other side.
I cut my front spacers to 1.5" length. This equals out to a hair more than 2" of lift due to the leverage of the "A" arms. The rear spacers are cut to 2" for that much lift. If I were to do it again I might go 1.75" for the front...I'm putting a winch on next weekend and I'm concerned about it sagging a little. From what I've read thats about as much you want to go for just a plain old spacer lift in order to maintain proper cv angles. When you install them dont forget to reuse the rubber isolator pad at the top of the spring.
The body lift was made from the plan on Zuwharrie, http://www.zuwharrie.com/content/view/11/27/    I wont go into detail there...the article does a pretty good job of explaining. Only one thing to note about it though; it says to drill one hole in your body spacer to 1/2" and the other to 3/8". It was mine and others' experience that both holes must be drilled to 1/2". This method of body lift actually nets you around 3.5" of lift.
On a final note, I did have to cut my front fenders and do some hammering on the inner fender to be able to turn to full lock. I cut about 1.75' at the bottom of the opening tapering into the natural arc of the original opening at point about 14.5" up from the bottom (in the side picture the fenders are not yet cut). I've been informed that a 3.5" to 3.75" back spacing on the rims eliminates much of the clearance issue...but I like tha wider stance of the 2.5" back spacing.
If you have any more questions feel free to ask me.
92 Tracker
     3" Cold air intake
