coil suspension system for samurais
  • 15 Replies
  • 5415 Views
Offline elotsip
  • 42
« on: January 04, 2005, 06:56:07 AM »
Does anyone have any experience with the coil suspension system from RRO for the samurai?
http://www.rocky-road.com/coil.html
Is it as good as they claim?
How tough is it to install?
Bill
Re: coil suspension system for samurais
« Reply #1 on: January 04, 2005, 06:57:27 AM »
Do you know ART ?  ;D       try nczuk.
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #2 on: January 04, 2005, 08:25:40 AM »
Bill
It is not an easy install. It requires a LOT of welding and a LOT of grinding. Yes, it is as good as they say it is. I've installed 3 of them now. Can do it in my sleep ;D
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #3 on: January 04, 2005, 08:26:43 AM »
I know art!!!
www.iknowartlilley.com ;D ;D ;D
Offline mesjr2004
  • 422
« Reply #4 on: January 04, 2005, 09:17:15 AM »
why couldnt you adapt that kit to a trakick?
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #5 on: January 04, 2005, 09:23:59 AM »
I dunno? Why couldn't you? I think it could be done.
« Reply #6 on: January 04, 2005, 09:28:57 AM »
It looks like they lowerd there price on them almost 200.00 buck's also, cool  8)
Offline elotsip
  • 42
« Reply #7 on: January 04, 2005, 10:10:52 AM »
That sammy looks great! What do you reckon it would cost to get that kit installed? I don't have the tools (or the know how) to do it myself but it looks so sweet!
I figure why spend $900 on a lift when I could spend $1600. I'm sure my wife won't like my logic. :D
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #8 on: January 04, 2005, 11:47:19 AM »
If I were to install the lift I would ask no less than 800 dollars. I have seen 2 people pay more than 900 to have it done. It requires cutting off all the bumpstops, front shock mounts, spring hangers, and some other pieces, a TON of measuring and remeasuring, grinding some brackets to fit better, welding all new upper and lower spring perches, all new upper and lower control arm mounts, all new upper and lower shock mounts, pan hard mounts, grinding, painting and so on. I had my axles sandblased while they were out from under the Zuk as well and I painted and undercoated all the fenderwells and frame. I didn't want it to look like poo after all the work it took.
Offline shoyrtt
  • 161
« Reply #9 on: January 04, 2005, 11:48:05 AM »
I had my lift installed. Just make sure you get some references before you decide on a shop. And costs? You know what they say, money talks! ;)
Offline mesjr2004
  • 422
« Reply #10 on: January 04, 2005, 12:05:36 PM »
how well does it drive down the road?
Offline 1bigtracker
  • 3409
« Reply #11 on: January 04, 2005, 12:12:17 PM »
IknowArtLilley.com  ;D  their has got to be a story behind that?
stu
« Reply #12 on: January 04, 2005, 12:14:13 PM »
I springs are soft, so there is a lot
of lean in the corners, but the flexy
is what this kit is designed for
If you were to road this system alot
you might want to use a 200-225
pound spring, this kit has a 175 pound
spring
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #13 on: January 04, 2005, 12:36:37 PM »
stu
Why yes! Yes there is a story behind it ;D
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #14 on: January 04, 2005, 02:05:34 PM »
;D ;D ;D    8) 8) 8)    ::) ::) ::)
« Last Edit: January 04, 2005, 02:07:36 PM by whitfield »
