electric rad fan
  • 12 Replies
  • 3179 Views
Offline bus_driver
  • 479
  • the voices tell me different things
electric rad fan
« on: February 22, 2007, 12:27:29 AM »
has anyone done a junkyard electric radiator fan on a 92 kick like mine??? is so what was doner fan from and how did you fit it. and did you notice any fuel savings????
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline BFM
  • 49
  • 4x4 oh yeah!
Re: electric rad fan
« Reply #1 on: February 22, 2007, 06:28:45 AM »
Just put your lift in already and lets go crush some stuff!!! ;D
'93 Geo Tracker, 3" suspension lift, 31" tires, dome light replaced with cadilac LED brake light bar, tinted, towed home once, dropped off of tow truck once, top speed attempted/achieved 135 km/h = shaking baby syndrome
Offline bus_driver
  • 479
« Reply #2 on: February 22, 2007, 07:19:22 PM »
oh that warm weather really got me going now I am really looking forward to it I have already figured out how to gring the holes accurately and I am really champing at the bit to get on the bike or in the truck now.....and then I wake up to snow this morning and I was like shit now I can't start the bike....like i was actually gonna but we are going soon i have thurs/frid for the next 6 weeks so we will hit Raglan or that spot u found up north of me. and this time we will do the trails with a camera ......no guarantee that we will use it but we will have it tho ....hahaha
call me soon to make plans
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #3 on: February 22, 2007, 07:50:05 PM »
i used a ford taurus fan, fit infront of the rad and works awsome
Offline bus_driver
  • 479
« Reply #4 on: February 22, 2007, 07:57:28 PM »
in front as in not between engine and rad but in the grille area? did you hook it up as a manual switch or sensor controlled? thanks for the info. also how was mounting done? just made tabse to go on frame type idea?
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #5 on: February 23, 2007, 04:11:06 PM »
yes, it is mounting infront of the rad as in by the grill.   I made a braket that bolted onto the original holes in the radiator support.  It is wired up to a external switch inside so i can turn it on went gets hot, and cheaper to set up.  I'm planning on taking the mechanical fan off and installing another ford taurus fan in place of the mechanical fan, this fan would be wired to the key so when the key turns over it starts spinning, there will also be a inline switch under the dash for this fan so when entering mud or water it can be turned off.  I'm hoping taking the mechnaical fan off will let me gain a little power and stop power loss when hitting water holes.
Offline bus_driver
  • 479
« Reply #6 on: February 25, 2007, 12:33:09 PM »
so the single fan is not enough to keep things cool then....I am looking at replacing my stock fan for the exact reason. power and fuel savings. I think I will go to the junker and research.
thanks man
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #7 on: February 25, 2007, 03:03:04 PM »
well, the clutch for my mechanical fan is pooched so i might as well switch to electric now.  I think that a single fan is enough to keep it cool in the summer on the pavement while cruzing but for me anyways when its over 40C or over 100F wheelin going slow threw trails mine would overheat.  So i will have the regular electric fan always running and when in summer and its overheating i can turn on the other fan and have double electrics turnning.
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #8 on: February 25, 2007, 08:55:08 PM »
I removed the stock fan and run a pusher fan from an A/C equiped Kick in front of the rad. Seems to keep up just fine now that I put a new rad in
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline zuk jockey
  • 32
« Reply #9 on: February 26, 2007, 06:41:16 PM »
    would two fans do any better than 1 if there both raveling the same speed. seems redundant. it would be cool to be able to shut the fan down, in one of my sammis the fan got sucked into the rad when going through water that sucked i watked a long way because it was overheating.
1994 sidekick soon to have 33s
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #10 on: February 26, 2007, 10:39:37 PM »
thats one of the reasons im doing that.  and you don't put the fans inline with eachother, make one fan more off to one side and the other off to the other side.  cooling more and pushing more air.
Offline bus_driver
  • 479
« Reply #11 on: February 27, 2007, 12:20:23 AM »
the water, winter, and fuel savings is the main reasons...water is self explaned and the winter is a bitch right now as my fan is cooling the damn truck down whlie I am trying to heat it up, and there is a dude in a xterra who went from 390-400kms/ tank to 500kms per tank and that is with a lifted truck so I figured it would kill many a bird with that stone.
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #12 on: February 27, 2007, 06:08:41 AM »
I have run electric fans on my sammy's for years. You only need 1 good size fan. One with a shroud if you mount it on the engine side. I don't even turn mine on in the winter unless idling in town for a while. I can't remember what mine came off of. Most FWD cars have decent fans in them.
